587,615 active members*
3,503 visitors online*
Page 75 of 76 256573747576
Results 1,481 to 1,500 of 1506
  1. #1481
    Sep 2013
    24
    Re: Mach3 2010 Screen set
    I do appreciate all the input I was just going to buy Gerry’s screen set but wasn’t sure it would work with old setup. This all started after a couple of failed button scripts to zero xy laser pointer.
  2. #1482
    35538
    I'm confused. Are you using the BigTex screen, or the 2010 Screen?
    Are you using the parallel port on your old PC?
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
  3. #1483
    Sep 2013
    24
    Yes using Big Tex 3.4, parallel port, mx3660 controller
  4. #1484
    Hello, does anyone know what is the latest version of mach3 2010?
  5. #1485
    35538
    I'll have to look when I get home. But it hasn't changed in the last 8 or so years.
    Gerry
  6. #1486
    thanks, I have the 2010-screenset-1.1.4 version for 3 years and wanted to know if there were any changes.
    Greetings
  7. #1487
    35538
    No, that would be the latest version. There won't be any further changes.
    Gerry
  8. #1488
    Using Mach3 and want to purchase the mach3 2010 screen set. Im using the Mach3 USB controller by Bitsensor ( Attached ), is there anbody using it with 2010 screen set, or anbody know if it works with that Board. Thanks
  9. #1489
    Jul 2006
    139
    Quote Originally Posted by Weliechiko View Post
    Using Mach3 and want to purchase the mach3 2010 screen set. I'm using the Mach3 USB controller by Bitsensor ( Attached ), is there anybody using it with 2010 screen set, or anybody know if it works with that Board. Thanks
    If it works with Mach3 in it's stock form, then it should work with the screenset. The screenset is just an advanced rearrangement of the buttons effectively. There's nothing controller specific in it that I recall.
  10. #1490
    Quote Originally Posted by shorton View Post
    Thanks for the reply. The board works well with Mach3 in its stock form. I just wanted to corfirm first because on their page ( 2010 screen set developers ) they mentioned that there are some boards that do not work properly with some boards.
  11. #1491
    Nov 2017
    9
    Hello,
    This Mach 2010 looks pretty good.
    Do it works with chinese xhc mk4 ethernet board?
    Regards
  12. #1492
    Jun 2010
    4262
    Any failings will be likely due to the Chinese board, not the screen set. Some of the Chinese boards are ...
    Cheers
    Roger
  13. #1493
    Jan 2018
    1516
    Quote Originally Posted by Eveb View Post
    Hello,
    Regards
    Might as well buy an AXBB-E from cncdrive. At least you know you'll get support!.
  14. #1494
    Nov 2017
    9
    Quote Originally Posted by basilio View Post
    Good afternoon.
    After uninstalling everything and reinstalling, I tried the Chinese Motion Controller macros and ... WORKS !!!
    Therefore, "Mach3Version3.043.062", the latest version of the "NcUsbPod.dll" plugin and Chinese Motion Controller macros, works perfectly.
    Thank you very much
    Looks like someone solved to my question
  15. #1495
    Jan 2019
    1
    Hello, I bought the 2010 screenset a few years ago and it worked fine with the parallel port, now I'm trying to upgrade to USB or Ethernet but I can't get it to work. All movements are done well with the exception of Auto Zero
    I wonder if anyone can help me, I have dealt with EC300 and NVCM6 v2.1 motion controllers
    Thanks in advance.
  16. #1496
    Jun 2021
    2
    Hi sir
    Did you try the 2010 software ? I’m running the same
    Board as you was in the time your posted in here.
    Best regards
    Kasper
  17. #1497
    Jun 2021
    2
    That’s sad. I will love a 5 axis!
  18. #1498
    Hello I just bought the 2010 screenset. Just making sure it is still supported and still I will get my download. Thanksl.
  19. #1499
    Quote Originally Posted by LeifMerget View Post
    I came here for the same reason. Hoping to get a email soon with the download.
  20. #1500
    Dec 2012
    38
    The last activity by ger21 was 06-12-2022 02:48 PM - you could try contacting him at cncwoodworker at comcast dot net
  1. Mach3 screen set
    By PEU in forum Screen Layouts, Post Processors & Misc
    Last Post: 11-28-2014, 11:00 AM
  2. Econo-Probe Setup with Mach3 + Ger's 2010 Screenset
    By jmc2010 in forum CNC Machine Related Electronics
    Last Post: 06-24-2014, 04:21 AM
  3. G100 + Mach3 2010 screen auto tool zero
    By Menatep in forum G-REX
    Last Post: 05-02-2014, 10:13 PM
  4. Strange Issue with 2010-4 Screen Set in second machine profile
    By JoeKumanchik in forum Mach Software (ArtSoft software)
    Last Post: 03-30-2014, 11:27 PM
  5. New Mach3 Router Screen
    By ger21 in forum DIY CNC Router Table Machines
    Last Post: 07-08-2008, 03:06 PM
