585,927 active members*
3,344 visitors online*
Results 1 to 4 of 4
    May 2005
    925
    Mach3 screen set
    I just finished a new (and my first) 1024x768 screen set for Mach3.
    Here is the preview:
    (resized to 640x480 here)
    You can unzip it to the mach3 folder safely since it uses its own
    bitmaps, the default ones aren't touched.
    The set is based on the default set but I added the following to the
    main screen:
    Added a MDI input line
    Added an unit selection box
    Added a G53 X0 Y0 Z0 button to move to the absolute zero coordinates
    Added a Z setting area with jog buttons and feed % for this movement.
    Removed 4th Axis DRO
    Removed Spindle Speed section
    I tried my best to respect the look and feel of the original set.
    Hope you all like it.
    Pablo
    Attached Files Attached Files
    Apr 2004
    439
    thanks for sharing
    Jan 2012
    0
    Hello, I like the screen, do not know where I can download a with resolution 920x 1080? thanks
    Nov 2014
    1
    Re: Mach3 screen set
    thanks
  1. Mach3 blue screen
    By Tony611 in forum Mach Software (ArtSoft software)
    Last Post: 12-26-2009, 05:55 PM
  2. mach3 display screen
    By woodman08 in forum Mach Mill
    Last Post: 08-18-2009, 05:45 PM
  3. Mach3 View Screen too BIG
    By Mr.Chips in forum Mach Mill
    Last Post: 01-01-2009, 10:35 PM
  4. Mach3 Router Screen.
    By ger21 in forum Screen Layouts, Post Processors & Misc
    Last Post: 07-24-2008, 08:47 AM
  5. Personalizar el screen del Mach3
    By Creisen in forum Spanish
    Last Post: 07-19-2007, 01:30 AM
