587,470 active members*
3,053 visitors online*
    Oct 2009
    77
    Pocket Toolpath
    Is there a reason why in the pocket toolpath there is no cutter compensation for the rough and you have the option for cutter compensation only for the finish pass ?
    Dec 2008
    3126
    Because---
    There are many options that can give various path strategies
    Many of these strategies involve crossovers, reversals, tight corners etc, and if cutter comp is used ( wear or control ) can give very unpredicatable and catastrophic results.
    Now couple that with a pocket of no real fixed shape ( rectangular, figure 8, islands, the variations are endless ) it is better to have no comp at all and only need to have comp when finishing walls
    I, Myself, only rough pockets leaving material on the desired faces, and use a seperate op for actual finishing ( if size is wrong, then I would only need to run the finish op, not try and find the finish sequence in the roughing op )
    Sep 2007
    126
    Smile SO TRUE
    Quote Originally Posted by Superman View Post
    Do it this way, all the time.
    Harold C.
    Oct 2009
    77
    Thanks for the response...
    Another question with the pocketing toolpath. When does one use an "island facing toolpath " as compared to a standard pocket. All the examples I've seen and done have only use the "standard" pocket.
    Sep 2007
    126
    Smile Like This
    When one has a pocket with protrusion's in it
    Regard's,
    Harold C.
  1. Replies: 6
    Last Post: 12-19-2008, 11:23 PM
  2. Better Way To Pocket In X2?
    By Mastercam User in forum Mastercam
    Last Post: 12-06-2007, 03:44 PM
  3. Replies: 10
    Last Post: 12-03-2007, 04:47 PM
  4. changing mill pocket toolpath to lathe-v9
    By scolee in forum Mastercam
    Last Post: 03-25-2007, 03:39 PM
  5. Pocket help
    By tt_raptor_90 in forum Mastercam
    Last Post: 06-20-2006, 03:37 PM
