I having trouble selecting the proper toolpath this partially tapered wall pocket. I thought HS clearance to start - followed by HS scallop to clean it up. Verify looks good, but when I run the part, HS clearance pass pretty much cuts straight down and the scallop pass touches nothing. I made every adj possible with offsets & stepovers - still the same result.
I tried Wire/lofted - which the verify looks great - except goes it goes through the floor of the part.
I'm using X2 - and the angle of the taper is 25 degrees...
I'd appreciate any suggestions.
Thanks,
Kevin
