587,818 active members*
3,157 visitors online*
Results 1 to 12 of 12
    Jul 2009
    86
    VF3SS SMTC Alignment
    Hello,
    I recently purchased a VF3-SS and I have a question regarding the tool changer.
    When the SMTC arm puts a tool into the spindle, it seems like there might be some mis-alignment. It appears that the tool tips sideways when the drawbar clamps. It also looks like the drive dog is clipping the tools slightly.
    I put a long drill in as a visual reference and the tip of the drill tilts when the draw bar clamps. It's easiest to see at 100% rapid but is also visual at 5%
    Does anyone have some suggestions of what I could check before calling the HFO?
    Thank you.
    EDIT - added a video, you can see the tool tilt sideways when it goes into the spindle. I'm assuming this is not normal but it doesn't make any bad sounds.
    Nov 2007
    479
    Re: VF3SS SMTC Alignment
    If its under warranty, call HFO. Still doesnt hurt to call your HFO tech support to get their input.
    Feb 2010
    1184
    That tool change is way to fast for me to see anything in that video.
    You can check the orientation of the spindle drive dogs to the tool change arm. To check physical alignment in X/Y you will probably be better off calling in you HFO service rep to do it as they have special tools specifically for alignment.
    Jul 2009
    86
    Quote Originally Posted by haastec View Post
    I will get another video up at slower rapid speeds.
    The machine is under warranty so I will call my HFO, it just takes a bit of time to get someone out. I like to learn how to fix things on my own if it's possible.
    Thanks.
    Feb 2010
    1184
    Quote Originally Posted by colton_m View Post
    Thanks.
    Even if it takes a little time, let the HFO fix it if it is under warranty! I am all for learning and DIY jobs but don't go tearing into things while a machine, any machine, is under warranty so as not to give the factory or HFO reason to void any repairs.
    Hopefully you get this issue resolved quickly.
    Good luck!
    Jul 2009
    86
    Here's a better video that shows what's happening. Could anyone else with a mill compare and see if the tool change arm flexes like in this video?
    Also it seems to leave a mark on my tapers in two spots, I will get a pic up of that when I can.
    https://www.youtube.com/watch?v=DnbWpgOEB-Y
    Dec 2011
    295
    As I remember there is about .080/ .100 Z move of the spindle that you dont have. I'll be back Tues.
    Jun 2015
    119
    It looks to me like your spindle isn't quite aligned at tool change. It's maybe a half degree off? Not much, anyway. Just enough that it is catching the edge of the alignment tabs, then popping into place. I'd have the HFO realign it if it is under warranty. It probably just needs the parameter for tool change position readjusted. (I could be wrong about the cause-- best to let a tech take a look at it).
    ____________________________
    My blog: http://www.fletch1.com
    Feb 2010
    1184
    Good luck!
    I stand behind this statement. Let your HFO handle all warranty work!
    Jul 2009
    86
    So for anyone else interested, I got the HFO to have a look and the alignment was perfect.
    Haas has made a design change with the draw-bar on the newer mills. The spindle no longer jumps up and down that .100" we were talking about. So technically everything was fine, they did change the spindle Z position for tool changes slightly (approx. .03") and everything looks and sounds a lot smoother now.
    Feb 2010
    1184
    Glad they got it sorted out for you. :cheers:
    Jan 2004
    539
    Always interested to hear the "fix"
    Interesting to hear that the spindle no longer moves,
    Gary
  1. VF3 vs VF3SS - looking for opinions
    By colton_m in forum Haas Mills
    Last Post: 05-29-2015, 01:05 PM
  2. vf3ss and vf2ss
    By Delw in forum Haas Mills
    Last Post: 08-30-2012, 01:39 PM
  3. New VF3SS and VF9 arives
    By smallplanes in forum Haas Mills
    Last Post: 01-27-2012, 04:56 PM
  4. Loud at 12K RPM - 05 VF3ss
    By ccjung in forum Haas Mills
    Last Post: 04-03-2011, 08:52 AM
  5. To buy a Haas VF3SS
    By TheBigJW in forum Haas Mills
    Last Post: 05-11-2010, 10:21 PM
