tool probing is good for high volume machining cells where tool breakage might be an issue and needs to be monitored otherwise probing of any kind is generally over rated or under utilized , usually in a jobbing shop the machines are under constant supervision due to the typical low volume and quick change over , manually qualifying a tool literally takes seconds so I see no benefit to it . I'd suggest more worthwhile options such as macro's and depending on the type of machining that you do I'd suggest high speed machining ,
because of the short read ahead the machines are pretty jittery when it comes to tight point to point code , the high speed tends to smooth it out and allow the machine to run at the programmed feeds without any delay , Ive programmed parts that were heavily coded and should have been running at the programmed 100-120 ipm but in reality were running at roughly 75ipm because of the short read ahead
A poet knows no boundary yet he is bound to the boundaries of ones own mind !! ........
