587,466 active members*
3,220 visitors online*
Page 1 of 2 12
Results 1 to 20 of 21
    Nov 2009
    79
    Tapping 3mm holes at 5mm deep
    I have to tap 3 3mm holes at 5mm deep. I heard that you need to use "form tapping" for small holes. I do have 3mm HSS hand taps, will that work? This will be a small production run, at a few hundreds of these 3mm tapped holes.
    thanks
    Daz
    Nov 2009
    79
    Re: Tapping 3mm holes at 5mm deep
    to make it worse, it's blind hole...
    Should I drill deeper than 5mm?
    Quote Originally Posted by dalianharley View Post
    thanks
    Daz
    Aug 2011
    135
    What are you tapping into? Note that you need to use a larger tap drill if using a form tap. Thread milling is likely the best option for a blind hole. But that's a lot of black magic if you have never done it before
    Sent from my VS980 4G using Tapatalk
    Nov 2009
    79
    it'd be 6061 alum
    it's not a very stressful part, just to hold a plastic guard.
    Thread milling...geez more stuff to learn
    Quote Originally Posted by mioduz View Post
    Aug 2011
    135
    Tapping AL can be finicky. It can be gummy on the finer threads. Personally I'd thread mill it but that's going to cost you buying thread Mills and likely wrecking one in the process. Prepare for likely the most costly tool you'll ever buy dollars/pound. Once you get all your settings right you'll wonder why you ever bought a tap in the first place. Getting there though may test your religion.
    Jan 2007
    1795
    if youre not prohibited, and workpiece let you, then drill it at least 11 mm deep
    even its several hundred, still worth to tapping by hand,, not with a simple crank but a tapping guide..
    see picture..
    actually for this short thread you could make some simple taping stuff..
    even some woodframe with a bushing could hold the tap.. it just a few mm travel..
    what is important sure it working easy so you feel the tap were tighting up..
    picture is just an example.. a lot simpler you can make..i think you can tap around 70-100 in an hour with a guide
    Jun 2008
    1082
    A thread-mill that can do a 3 mm hole would be miniscule! Personally, I wouldn't recommend trying it. I'm sure it can be done, but if you're doing a few hundred holes you'd probably want something faster too.
    I've tapped several* M3 holes with a forming tap using a Procunier tapping head. I pre drill with a 2.75 mm drill to a depth 0.5 mm deeper than I plan to thread (at full diameter - the bottom point of the hole is probably about 0.65 mm deeper). The tap turns black from oxidizing aluminum so I try to hit it with compressed air to clean it off quickly between holes.
    The Procunier is very expensive, but it works well and is very fast. There are cheaper tapping heads available, but the majority that I've seen have a clutch adjustment that is, as I understand it, basically done by 'feel'. That kind of guesswork doesn't appeal to me, which is a big reason I went with Procunier.
    Here's a video I think you may find useful if you're considering a tapping head...
    https://www.youtube.com/watch?v=IIv8xH9razE
    This also looks like a very cool and versatile machine...
    https://www.youtube.com/watch?v=FZLU-F9wcS0
    If I remember right: at least one Flexarm model is basically the same price as a Procunier Tru-Tap head, but it looks like it would be more versatile, albeit slower. As you said: more to learn.
    * maybe 30 or so - not a ton, but enough to be confident that the process I'm using works OK
    Feb 2006
    7063
    thanks
    Daz
    The answer to your question depends a whole lot on HOW you intend to do the tapping. Are you using a reversing tapping head, or a tension/compression holder?
    In general, standard hand taps, i.e. "plug" taps, should not be used for machine tapping. They are likely to get clogged with chips, bind, and break. Spiral point, spiral flute, or form taps are recommended. Threadmilling is an option, but not a very good one for such a small size. Remember a tap is tapered, so if you need 5mm of useable threads, you'll have to run the tap quite a bit deeper (probably almost 2X). Or, you can machine tap, then use a bottoming tap and chase the thread by hand to remove the taper from the lower threads. Also, since you don;t have a servo spindle, you need to drill the hole extra deep, to make sure the tap can't bottom out (which WILL break it). Further, spiral point taps push the chips ahead of them, so you have to also allow extra room for the chips.
    My recommendation would be a reversing rapping head, as it gives you pretty good control over depth, assuming your spindle speed is accurately known. I would use a spiral point tap, and drill the hole at least 3X as deep as the threads you need, and run the tap in 2X as deep as you need. Use lots of tapping lube, and blow the chips off the tap between holes.
    If that all sounds too complicated or expensive, spend about $80 for a "hand-tapping fixture", and just do them by hand. It's quick, easy, and relatively fool-proof. Not as fast as CNC, but you'll probably get it done without any broken tools and scrapped work.
    Regards,
    Ray L.
    Aug 2011
    135
    looks like most manufacturers stop at M4 on thread mills so you will have to use some kind of conventional tapping technique. Im sorry for sidetracking the topic with a technique thats not applicable here. Surely you could probably find someone to make you one custom, god knows the price and it would be incredibly delicate. I HATE tapping blind holes, and I do it for work many times a week.
    Jan 2005
    238
    Spiral flute taps used with a reversing tapping head would push/pull the chips out of the hole. My experience with small taps is somewhat limited, I rarely see anything smaller then 6-32. I adjust the clutch on the Tap-Matic head to avoid breakage on blind holes. It also works great in a drill press provided you can spin it slow enough, and if you hit bottom, you just release the handle and out it goes. Definitely clean the tap between holes and ad cutting fluid such as A-1 before attempting to tap the next hole.
    Aug 2011
    77
    i would use a roll forming tap they work awesome just make sure you use the right drill size you will do all 100 holes with one tap use cutting oil on ever hole
    Jun 2008
    1082
    Spiral flute taps are cool too, for sure. Below is (basically) my first foray into machine tapping. This is a spiral flute tap, as you can see: it works quite well. Now I only use forming taps because I like that they're likely stronger, likely produce stronger threads, and because it's nice that they don't produce chips.
    https://www.youtube.com/watch?v=VGhm96ntPAY
    Dec 2012
    194
    Daz,
    How many of these parts do you have to make? That information can help in the decision on which way to proceed.
    Nov 2009
    79
    Quote Originally Posted by LRF View Post
    Daz,
    First 12 of them, 4 identical part with 3 holes each. Then maybe a small run of 20 sets, that's 240 holes. I'm gonna try spiral and form tap see which one I like better. You guys are awesome, better than any book I bought lol. Power to the collective wisdom.
    Jan 2007
    1332
    I have tapped 10's of thousands of blind 4-40 holes 1/4" deep in 6061-T6 on my Tormach using a Balax form tap and Procunier reversing tapping head. BTW #4 screw is approx 3mm. Tormach Procunier Tapping Video by miltons_stuff | Photobucket Haven't tried threadmilling a blind hole that small because the form tap and Procunier have worked so well.
    Don Clement
    Nov 2009
    79
    oh man that looks gnarly. I got the tormach compression tap head and this will be the first job for it!
    I'll follow up after I give it a try. Now i have to source a 2.8mm drill. any recommendation on where to source them?
    Quote Originally Posted by Don Clement View Post
    Don Clement
    Feb 2006
    7063
    Just use the closest Imperial drill - 0.110 =>7/64, #35 or #34.
    Regards,
    Ray L.
    Jun 2008
    1082
    GUHRING 2 8mm 0 1102" Solid Carbide Drill Series 730 High Performance | eBay
    I bought a whole bunch of drills from this seller...
    zorotools on eBay
    But they don't seem to have any 2.8 mm drills at the moment.
    Here's a 2.75, which is the size I use for M3 forming taps.
    GUHRING 9005490027500 Jobber Drill List 549 Metric Size 2 75 | eBay
    And, this may be helpful...
    Tap Drill Calculator
    Jan 2007
    1332
    The Procunier reversing tap head is perfect for blind holes as it stops within 1/3 revolution. Can't say how a compression tap head works on blind holes.
    Don Clement
    Jun 2008
    1082
    dalianharley, if you decide to get a Procunier, and if you decide to buy a new one, I'd suggest buying it direct from Procunier. Call them up and have them install a quick change spindle for you - I believe this is a free upgrade. The only downside that I'm aware of with the quick change spindle is that the collets are more expensive. The quick change collets are ~$50 each instead of ~$30 each if I remember correctly. For the 15000 series Tru-Tap head (which is what is shown in the last video I posted) you're only likely to need 4 collets* so they'll cost ~$200 instead of ~$120.
    Don Clement, you're a fan of the quick change collets too, right?
    * what I would call a "complete set" of collets...
    58811 - #6 Pro-Quick collet
    58818 - #8 Pro-Quick collet
    58824 - #10 Pro-Quick collet
    58838 - 1/4 Pro-Quick collet
Page 1 of 2 12
  1. Deep holes
    By keithmcelhinney in forum Novakon
    Last Post: 09-17-2013, 01:09 PM
  2. Drilling deep 1/2" holes?
    By lukaslouw in forum MetalWork Discussion
    Last Post: 07-30-2008, 03:08 AM
  3. deep drilling 2mm holes
    By kesparate in forum Uncategorised MetalWorking Machines
    Last Post: 09-16-2007, 05:57 AM
  4. Deep holes in 6061
    By racerdog in forum MetalWork Discussion
    Last Post: 06-17-2006, 08:09 PM
  5. Drilling deep holes.
    By HSM Joe in forum DNC Problems and Solutions
    Last Post: 05-13-2003, 06:14 PM
