^^^ It's funny because it's a switch I have to forcefully turn off. I want to try and run everything at full tilt, often just as a chance to learn more about the "limits". It took some work to make myself turn the feeds down from 90 IPM to 60 IPM and then I also started with 3 of each part knowing I needed one good set.
Trying to figure out a whole bunch of what if's, but this specific project/product is looking to be the green light for a new VMC in the garage. Looking at new or used Super Mini Mills, Sharp 2412's, and Hurco VM10i. I plan on creating a typical part with roughing and then surfacing, with a hand full of tool changes and then seeing what the cycles times are for each machine - running the same code. I know the new Hurco control runs HSM and surfacing toolpaths really well/fast. I think Haas with their HASM module is just OK, and Sharp with the basic Fanuc control I fear will be the slowest. But I really want to see how they stack up.
PM-45 CNC conversion built/run/sold.
