587,380 active members*
3,188 visitors online*
Results 1 to 4 of 4
    Nov 2014
    2
    pc wont connect to laser cutter
    Hi everyone
    I bought a chinese laser cutter off eBay
    i thought i was buying from a uk based seller plowlive-uk
    But it turned out it was a direct from china seller, after it arrived.
    Anyway i got it, unpacked it, set it up & checked it worked
    Then didn’t get to use it for a week or two due to work commitments
    i installed coral laser & laserDRW as the booklet said
    1st problem coral laser doesn’t work at all
    But the laserDRW did so drew a simple txt name just to see if worked properly
    i plugged in the memory stick in & tried to cut
    when i tell it to cut it displays 'Need driver installing' i can’t find a driver on the stick or the disc at all (to be honest I’m not shore what the memery stick is there to do as it doesn’t seem to have much on it.
    From reading some of the boards this seems like a common problem
    The information I’ve found for this machine is
    Device id: A0C74F11482D42F7
    Mainboard: 6c6879-laser (I think)
    Company/maker : Zhongpu
    Model : zhongpu-460
    if anyone could help it would be greatly appreciated
    also laserDRW isn't that great ,could anyone tell me of a good drawing program which would work on this machine
    cheers Tony
    Jun 2013
    45
    Re: pc wont connect to laser cutter
    Tony
    I think you will find that the USB stick is a dongle for the laser software that you were supplied with. I'm guessing that you were given LaserCut as the laser software. LaserCut requires a dongle to operate. You must have the dongle plugged into the computer that you use to create the file that you wish to cut/engrave.
    If my guess is correct, you need to install the driver for your controller (probably Leetro 6515 or similar?) and the driver for which ever version of software (LaserCut or CorelDraw) that you wish to use to control the laser. You can use either LaserCut or CorelDraw to drive the laser machine. Myself, I was never successfull in using CorelDraw to drive the laser.
    My workflow was;
    Design in CorelDraw -> save to dxf file -> import dxf file into LaserCut -> use LaserCut to cut/engrave project.
    You can also export your project to USB stick from LaserCut and then print directly from the machine.
    If my guess is incorrect, then none of the above is relevant for each laser controller uses specific software to drive it. I only have experience with LaserCut and LaserCad - anything else and I can't help you.
    Try and find out exactly which controller you have and then people with experience with that software will be able to help.
    Sep 2011
    58
    Hi Tony,
    What is your mainboard name: MPC6515? Or MPC6525? Leetro control card, better use XP computer, If win 7, you'd better use Win 7 32 bit. If win 7 64 bit, it would be a bit difficult to recognize USB driver.
    It is better if you can send us control card picture, then we'd like to give you updated file or driver. Please contact me by [email protected]
    Best Regards
    Lucy
    Jinan Consure Electronic Technology Co.,Ltd
    www.jncslaser.com
    Lucy (Jinan Consure Electronic Technology Co.,Ltd) 0086-18254116182
    Web:http://www.jncslaser.com Email: [email protected] Skype:consurelaser
    Hello Tony,
    Good moring to you. How are you today?
    I am Sherry from SUKE Laser company specialized laser machien with CE&FDA certificate.
    About your problem: maybe you do not install the driver suceesfully, please check the device manager, to see if there is some paces mark yellow color?
    Meanwhile, please keep your dongle in your computer when operate.
    At last, could you give me a picture of your control box, so that we check where is the problem?
    My MSN:[email protected]
    My Skype:sukelaser08
    My email: [email protected]
    My mobile:0086-18668916435
    Best regards
    Sherry
    Quote Originally Posted by rockgod2304 View Post
    Hi everyone
    Model : zhongpu-460
    cheers Tony
  1. Laser table wont lift up (GCC/ Laser Pro Mercury II)
    By aussiemate in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 07-30-2014, 01:34 PM
  2. Laser cutter wont cut/engrave
    By jassk in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 10-14-2013, 01:26 AM
  3. Replies: 5
    Last Post: 11-08-2012, 02:44 AM
  4. How to connect laser power supply?
    By Alex101 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 03-14-2008, 07:50 PM
