587,771 active members*
3,015 visitors online*
IndustryArena Forum > CAM Software > OneCNC > One CNC Vs BobCAm
Results 1 to 4 of 4
    Jun 2007
    394
    One CNC Vs BobCAm
    Hi All
    I am currently using BobCAM for SolidWorks
    i just wanted to get opinions on switching to One CNC (Pro's and Con's)
    Can I post G Code for Mach 3 Mill and Lathe via One CNC?
    Does anyone have a link to a demo version of the software and a rough idea on pricing?
    Nov 2010
    21
    Re: One CNC Vs BobCAm
    Onecnc will post G code for Mill and Lathe. Mill and Lathe are two different packages though. I have used everything from Meshcam, VisualMill to Mastercam. Onecnc XR5 Pro works great and I have been reasonably happy with it the last couple years.
    The biggest pro is support without annual maintenance fees. The software is easy to use but like every piece I evaluated or used--they all require some work around for some operations. Whether it drives you nuts depends on your parts and how you approach them.
    Since you already have Solidworks I would advise you to try out a free copy of HSMWorks Xpress before you do anything else. Solidworks/HSMworks seems to be the direction that most move after a few years of experience. From what I understand you can't beat the power for 2.5D CAM and the price is right.
    Apr 2009
    5516
    Cons - OneCNC is not integrated into SolidWorks. OneCNC likely costs more. Some people may actually prefer a menu-driven system rather than a wizard-driven system (though I believe BobCAM uses wizards now?)
    Pros - I actually prefer the look and feel of OneCNC. I programmed parts in about 10 minutes without even reading any manual (XR3). I have XR4 Mill Expert and the CAD side leaves a little to be desired, but works for my needs; XR6 is leaps and bounds better (though I don't have it yet.) BobCAM has added more machining strategies that I'd like, but so has OneCNC. No maintenance fees are a plus, and the phone and forum support are great. The best part is you won't have to deal with the incessant nagging from BobCAM salespeople, and I've been through it and it is frankly horrible.
    I use Mach3, though I cannot remember which post-processor I used. I also use USBCNC from EdingCNC and can post gcode with the FANUC 21 post processor.
    Mar 2009
    88
    I used Bobcad for a while then switched to XR4 then XR5. Truth is, Bobcad is cheap basic entry level software and fits well for a hobbyist or someone who isn't concerned with time and frustrations. If quality and advanced machining processes are important, one needs to step up to more powerful, machinist duty and intuitive software. OneCNC works and works well. I can't say enough about Patrick at OneCNC West. If you have any questions, give this guy a call.No sales tactics, pressure, just honest free advice.
  1. BobCam V3
    By oldraven in forum BobCAM for SolidWorks™
    Last Post: 09-09-2013, 07:40 AM
  2. New to bobcam
    By westerfieldcct in forum BobCad-Cam
    Last Post: 11-07-2010, 04:24 PM
  3. BobCAM
    By CNC_Nick in forum Community Club House
    Last Post: 12-22-2009, 07:52 PM
  4. Anyone using BobCAM?
    By kevperro in forum Tormach Personal CNC Mill
    Last Post: 08-24-2009, 05:52 AM
  5. bobcam v12.5.2
    By vividdezigns in forum BobCad-Cam
    Last Post: 08-19-2008, 07:48 PM
