587,415 active members*
3,609 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > Okuma And Howa Act 5 Lathe
Results 1 to 6 of 6
    Oct 2015
    17
    I just recently got an Okuma & Howa Act 5 Lathe, while testing out the controls for it, I hit the +X overtravel. I am unable to clear the alarm as it is still sitting in the same position and am unable to move the tool body.
    After searching online I found that you can push a button in the electrical cabinet labeled "over travel release", but I am unable to find this button. I need to fix this as soon as possible.
    Any help would be appreciated.
    NorthMachininst
    Mar 2009
    1982
    Re: Okuma And Howa Act 5 Lathe
    Look at regular switch on the front operator panel. Place picture of the operator panel here.
    Oct 2015
    17
    Quote Originally Posted by Algirdas View Post
    The unmarked switch is believed to be the HYD switch from the electrical cabinet as it is missing in there
    Jun 2015
    4156
    this one ? not sure, but i used it when one axis overtraveled ....
    May 2014
    174
    Quote Originally Posted by NorthMachinist View Post
    NorthMachininst
    Hello NorthMachinist, I know this is a very long shot but I would like to know if it`s possible for you to share a set of paràmeters from your machine. It will be greatly appreciated.
    Flex
    Nov 2007
    364
    Hold the Power on button or control on and can you hear the Hyralics click on ? ---Keep holding it and have the machine in manual on that axis and move it to the minus ---this is an older Fanuc 6T control on this one
  1. Replies: 0
    Last Post: 11-18-2015, 10:49 PM
  2. Okuma Howa CNC Lathe
    By gearmachinist in forum Okuma
    Last Post: 04-25-2014, 02:17 PM
  3. need post okuma howa lathe
    By mike10 in forum Post Processors for MC
    Last Post: 07-03-2010, 04:33 AM
  4. 1988 Okuma Howa ACT3 CNC lathe issues
    By TimSchmidt in forum Okuma
    Last Post: 09-26-2008, 06:08 AM
  5. need help okuma howa lathe
    By mike10 in forum CNC Tooling
    Last Post: 09-17-2006, 02:10 AM
