587,482 active members*
3,425 visitors online*
IndustryArena Forum > CNC Electronics > Gecko Drives > Nema 23 8 wire motor to Gecko drive
Results 1 to 6 of 6
    Aug 2014
    11
    I am having a hard time understanding how to wire an 8 wire Nema 23 motor to a gecko drive. I am thinking from the wiring diagram that 4 wires from the motor will go back to each other and then 4 will go to the drive?? The color of wires coming out of the motor are:
    Black
    Red
    Blue
    Green
    Blue/white
    Green/White
    Red/White
    Black/White
    Any help would be appreciated and if this has been discussed before I apologize.
    thanks
    J
    Sep 2013
    9
    Re: Nema 23 8 wire motor to Gecko drive
    It's always best to check the manufacturer's recommendations, if they exist, but here's what Vexta recommends.
    Aug 2014
    11
    Thank-you for replying. I did get the wiring diagram, but I am confused because the wire colors coming out of my motor are not the same colors listed on the spec sheet. I think I am making it more difficult then it is but I really don't want to mess up the motor.
    These are the colors I have coming out of my motor.
    Black
    Red
    Blue
    Green
    Blue/white
    Green/White
    Red/White
    Black/White
    J
    Sep 2013
    9
    Right.
    Let's assume you will be using the bipolar parallel configuration, which is common.
    You can use an ohmeter to sort the 8 wires into 4 pairs.
    Then the next question is which two pairs are "A" vs. "B"? Perhaps the solid color wires are "A" and the mixed color wires are "B"?
    You'll end up with 4 pairs of wires that connect to the Gecko's 4 output terminals, as shown in the diagram I posted.
    If you can find your manufacturer's wiring recommendations, of course that would definitely be best.
    Sep 2013
    9
    Here's a diagram from Lin Engineering with colors similar to yours. However, I don't know if this is an industry standard color scheme or particular to their motor?
    Attachment 260666
    An ohmmeter will detect 4 pairs, but can't detect "A" vs. "B". The only way to be sure is to hear it from the motor manufacturer. :/
    Aug 2014
    11
    Yes I found the chart above also. I tried to wire based on this and I thought it looked promising. But it didn't work. Now I have another problem in that I can not bet my control box to turn on. It didn't quit right after I tried the motor. I was able to move the other 2 axis that I already had hooked up but then after some time I now do not get a green light in the back or a default red light. There is a small green light on inside the box and I looked at the board in the box and the fuse is still good. Any ideas?
    thanks
  1. Can I use a Gecko Drive with a DRC 8 wire encoder
    By cmacclel in forum Gecko Drives
    Last Post: 04-21-2013, 03:21 AM
  2. Gecko Drive for NEMA 42 Stepper
    By amishx64 in forum Gecko Drives
    Last Post: 04-06-2012, 07:41 PM
  3. Gecko 540 to drive nema 17s ???
    By NE Brownstone in forum Gecko Drives
    Last Post: 08-17-2011, 08:47 AM
  4. Wiring 8 wire hobbycnc with Gecko-like drive
    By Guldberg in forum Stepper Motors / Drives
    Last Post: 07-21-2009, 02:52 AM
