587,852 active members*
3,993 visitors online*
Results 1 to 17 of 17
    May 2010
    14
    Mitsubishi MDS-CH-CV power supply
    Hi, we have here a Yamazaki Mazak Machining Centre fitted with Mitsubishi MDS-CH servo drives.
    The Servo power supply has a 'C' on the display. Does anyone know what these codes mean? Mitsubishi say that only Machine Builders may learn of these codes.
    I've been told by various 'experts' that C means that its either ok, that it has a hardware fault, that it has a memory (parameter) fault...so Im none the wiser now.
    Nov 2006
    925
    Send me a PM with your email address.
    Mark.
    Mar 2009
    109
    6C means main circuit Error......"Charging of the main circuit has become abnormal"
    Isolate the PN bus on the power supply with the rest of the servo system. Measure the bus with a meter to see if there is a short. The problem is almost always the power supply itself.
    May 2010
    14
    Hello! The power supply is giving out 590V DC on the DC busbars, which seems about right. (AC supply is 415V AC 3-phase). The machine operator says that normally the power supply should show a letter 'b'.
    There's only a single digit 7-seg LED on these, so error codes are single characters.
    Jul 2007
    284
    Check this manual. http://www.meau.com/functions/dms/ge...00001040100000
    On page 66 it will list some things to try for 6C alarm. 6C should be showing on one of the attached drives and c is the equivalent on the power supply.
    May 2010
    14
    Hi onthebumper, many thanks indeed for the link, that is manual I've been looking for; it's not on the Mitsubishi UK website, and I can't externally access the USA mitsubishi website as it's blocked to non-US browsing for some reason!
    I've had my nose in the machine today and managed to get the boss to let me swap the suspect power supply with one from another machine; this proves that the error moves with the power supply.
    A good unit starts A > b > C > and finally d when it the CNC issues a drive enable command.
    The faulty unit starts E then changes to 'o' when the CNC tries to run the drives.
    We had a cooling fan start bad arcing at about the time this fault first showed up, (the fan motor was full of coolant); I'm wondering if the interference has somehow conducted into the servodrive and scrambled the power supply CPU or NVRAM ic. The boss wouldnt let me swap the CPU cards.
    I dismantled the power supply (I'm a former inverter VFD service tech) but can't see any component failure doing cold checks; no IGBT problems, electrolytics all test ok etc.
    Does anyone know if there's any parameters this PSU needs loading with? I'm all at sea with these MDS systems, I've had similar problems with Fanuc which I've been able to sort by fac.resets and parameter set reloads.
    Cheers,
    kevin
    Jul 2007
    284
    There are no parameters in the power supply unit. There is only software that is written to the power supply but this can only be done by Mitsubishi through special tools. On a side note the servo and spindle drives do have parameters but they are written from the control every time you power up so there is no need to manually write them or even back them up. For this reason it is very important to back up the NC parameters.
    May 2010
    14
    I guess that maybe the 'firmware' is corrupt! I'm going to send the psu away and win myself a large bill!!
    I'll post the outcome if they tell me the score.
    Kevin
    May 2010
    14
    Latest update to my little problem, the PSU was sent away to a dealer and they returned it saying they couldn't find the fault! So it's back here, at least it wasn't something so simple as to make me look like an idiot..though that's the least of my worries.
    Yamazaki Mazak UK are going to be the next port of call I suspect...that's bread and cheese for dinner for the next year then....
    Jan 2011
    350
    Power supply message C
    This means Ready ON, servo OFF.
    Aug 2009
    71
    CH-CV power supply
    The problem could be incoming power supply quality side. We had similar problem in year 2000, when Mitsubishi had launched MDS-B-CVE xxx Power Supply, which was not getting into ready mode at some customers.
    After many trials, we found it does not get ready if the supply frequency is not in the range of 50 Hz +/- 2 Hz, i.e. it should be 48 - 52 Hz.
    Temporarily we had replaced them with B-CV xxx & later Mitsubishi modified the firmware for the CVE units.
    Since the unit was working fine at their service centre, you can check the Voltage, frequency, temperature etc are within the limits in the shop.
    Anyway Mitsubishi are the best people to find out this.
    All the best.
    Girish
    Nov 2011
    0
    Smile
    please go through the remedies given......
    for more manuals visit CNC MANUALS
    Aug 2010
    7
    power supply failure alarm is certainly identified the friends C Power Supply does not measure anything, but I did not test all the components, V / I got my device but I can not find the fault. Greetings to everyone ... Do you have that will help you
    Aug 2010
    7
    Waiting for help from friends who are dealing with here, card repair
    Aug 2010
    7
    information specific to my e-mail so you can stay in the privacy issue would be grateful: [email protected]
    Nov 2011
    0
    Quote Originally Posted by metropol View Post
    Hi metropolasil,
    Please give me the below details i think i can help you.
    Machine details:
    drive model number:
    alarm in the drive:
    alarm in the NC:
    Aug 2010
    7
    driver no:MDS-B-CV-37
    IN DSPLAY ALARM : C
    POWER SUPPLY
  1. How'd you supply your power supply?
    By cnczane in forum DIY CNC Router Table Machines
    Last Post: 08-28-2011, 11:13 AM
  2. power supply
    By sa1 in forum CNC Machine Related Electronics
    Last Post: 10-08-2008, 06:22 PM
  3. More power from switching power supply
    By R.thayer in forum CNC Machine Related Electronics
    Last Post: 03-11-2007, 02:03 AM
  4. Power Supply from a computer power supply
    By jmytyk in forum CNC Machine Related Electronics
    Last Post: 01-11-2006, 09:56 PM
  5. DIY Power supply
    By mjarus in forum Mechanical Calculations/Engineering Design
    Last Post: 12-10-2005, 05:16 PM
