587,887 active members*
3,354 visitors online*
IndustryArena Forum > CNC Electronics > CNC Machine Related Electronics > More power from switching power supply
Results 1 to 5 of 5
    Oct 2006
    53
    Does anyone here know how I can get more power out of a switching power supply. Can you replace the transistors with larger ones or can I increase the duty cycle for the transistors. Anyone have any ideas please share them. Thank you for your time and hope to hear from you very soon.
    Aug 2006
    2758
    Quote Originally Posted by R.thayer View Post
    No, replacing the transistors is not going to improve it. You will have to use a different transformer otherwise you are going to increase core losses and the core temperature will rise. You will need to make some changes to the current feedback circuit. It all depends on the type of switching power supply. Do you have any schematics?
    Oct 2006
    53
    Tivo box power supply
    The power supply is out of a tivo directv reciever. Can I get more current out of the power supply without replacing the transformer. Can I increase the freqency that feeds the transformer to get more power.
    Aug 2006
    2758
    No, increasing the current is the same as increasing power. There should be an over-current protection. you can't override it or it is going to smoke. Switching power supply design is a lot more difficult than linear power supply design.
    If you had the schematics, (which I doubt, because most of the manufacturers don't publish them) You could have done do some customization, like re-wind the transformer for only one output voltage, and gain some extra power after a few changes to the voltage and current feedback circuit. But, a tivo power supply will never supply much power for anything CNC related.
    Jul 2005
    2415
    This is akin to rewiring your old TV to get HDTV.
    First you start by taking all of the components off the boards and throw them in a big box. Now put all new components on the cards. Turn it on. When it fails to work add the boards to the big box of components and set it out for the trashman on Thursday.
    Use the cabinet for a fish tank.
  1. How'd you supply your power supply?
    By cnczane in forum DIY CNC Router Table Machines
    Last Post: 08-28-2011, 11:13 AM
  2. Switching Power Supply
    By CharlieM in forum Stepper Motors / Drives
    Last Post: 05-08-2006, 02:17 PM
  3. Power Supply from a computer power supply
    By jmytyk in forum CNC Machine Related Electronics
    Last Post: 01-11-2006, 09:56 PM
  4. Linear Or Switching Power Supply
    By edbo68 in forum CNC Machine Related Electronics
    Last Post: 03-27-2005, 08:19 PM
  5. What is a "Switching" power supply?
    By EvanRobert in forum CNC Machine Related Electronics
    Last Post: 09-09-2003, 04:53 PM
