hello every 1 i need to know haw to print drawing with diamension..i make drawing in mastercam i know haw to print.... but i wont to know haw to print with diamension wich i need...so can N E one tell me plz...
Ok lets start by writing out what you want. I cant read what you are asking. What is a N E?
Cadcam
Software and hardware sales, contract Programming and Consultant , Cad-Cam Instructor .
Go to the Create drop down menu, then select Drafting then you select Dimension . The Dimension drop down menu will give you several options. Horizontal, Vertical, Parallel, Angular, and several others . Select the type of dimension your want to measure. You then click on the two points you want to measure and Master Cam will give you the correct measurement.
Create dimensions on the screen and print a hard copy
thnx for helping me i got it haw to creat diamension... once againe thnx lot....thnx mac010 .....&..... thnx mike .......
Print Hardcopy if for V9 and earler and File Print is for Mastercam X and on.
Cadcam
