587,794 active members*
3,042 visitors online*
Results 1 to 5 of 5
    Dec 2006
    406
    Keling power supply
    I have a keling 54v 13amp unregulated power supply with. It is a toroid transformer and a small rectifier board. When I first fired it up and tested it about a year ago it read +53.4, -53.4v and the common was about 28v. Now the supply reads +55.4v and -55.4v or close to that. What causes the voltage to change like that? The reason I ask is my board is 55v and I need to keep the voltage below that. Is there a way to lower the output voltage by just a couple of volts. I'm also wondering if I can add a fuse somewhere to protect against over voltage and over current? Any help or advice would be appreciated. Thanks
    Judleroy
    Dec 2003
    24220
    If your mains supply happens to fluctuate, the output will also, which can happen at peak demand times of the day.
    If you want to keep it down to below a certain level, the easiest way is to take a few turns off the toroid secondary, they are usually wound on last, ~2turns/volt.
    Al.
    Albert E.
    Dec 2006
    406
    Thanks Al I new you would have the answer. Is there anything I need to no to keep from messing things up while taking off the windings? Do I have to take the plastic off the coil to remove the windings?
    Judleroy
    Dec 2003
    24220
    Quote Originally Posted by judleroy View Post
    Judleroy
    Yes, it can be rewound on or use electrical tape, but you may not have to remove all of the insulating tape as it does not take many turns to reduce it.
    Just make sure you have the right secondary winding if there is more than one.
    I have often wound on a separate auxiliary winding on top for 5,12 or 24v, whatever I needed at the time.
    Al.
    Albert E.
    Dec 2006
    406
    There are 4 output windings off of the toroid. The toroid says they are blue-green-blue-green. The two blues together give me +54v and the two green give me -54v. The toroid says O/P: 1. Blue-Green and 2. Blue-Green. Would I take 4 windings from both #2 windings (blue and green) to remove 2 volts from the supply? Thanks Again
    Judleroy
  1. Keling power supply
    By yoyomin in forum Automation Technology Products
    Last Post: 01-23-2010, 04:00 AM
  2. Keling 5010 power supply wiring
    By ronncat in forum Automation Technology Products
    Last Post: 12-13-2009, 06:17 PM
  3. Keling Power supply
    By judleroy in forum CNC Machine Related Electronics
    Last Post: 08-25-2009, 06:08 AM
  4. Keling motors, drivers and power supply connections
    By Nitroghost in forum Automation Technology Products
    Last Post: 03-13-2008, 05:18 PM
  5. Keling power supply?
    By mcruff in forum Automation Technology Products
    Last Post: 09-24-2007, 03:11 AM
