587,704 active members*
3,489 visitors online*
Page 11 of 88 9101112132161
Results 201 to 220 of 1750
  1. #201
    Dec 2005
    59
    Your build and drawings look great . Thanks for all your hard work. I know it's somewhere but what is th overall size and cutting area?
    Wally
  2. #202
    Aug 2004
    3215
    Quote Originally Posted by wallyh
    Wally
    25"x49"x7"
  3. #203
    Dec 2004
    62
    Do you have a parts/price breakdown list?
    Herman
    Disclaimer: Not affiliated with any company or business. Happily Retired.
  4. #204
    Feb 2006
    26
    Quote Originally Posted by joe2000che
    Some people have asked for a kit that would not be all the MDF pieces cut but a part of each or the ribs for instance, in which they would use it as a template and produce their own parts from. (this would only be possible for the torsion boxes)
    If I get to the point of ever trying a CNC machine, I would be eager too get a single part and make my duplicates by template routing. For the parts that are special, I would still have to be a customer or resort to traditional manufacture.
    Thanks again for publishing your work. It truly is the fuel of my woodworking fantasies.
    Dale
  5. #205
    Dec 2005
    8
    Greetings Joe,
    I've got my software and electronics ready. I am going to be ordering some hardware like the Acme rods, drill rod, lovejoys, skate bearings,etc. What I'm really wondering is when a complete X, Y torsion box, gantry, and bearing support blocks/tool holder kit will be available? I would be happy to be a BETA test customer. Big deal if all of the marketing kinks arent worked out, your design speaks volumes! I have some tools for fabrication but I am not interested in reinventing the wheel. Your project looks like it is ready to be rolled out. Let me know what it will take to get this flying. Cabin fever has set in ( having a blizzard today) and am anxious for a good project.
    Best Regards
    BR
  6. #206
    Aug 2004
    3215
    Quote Originally Posted by cornfed
    Greetings Joe,
    Best Regards
    BR
    I will be finished with it by this weekend, I will put the Z axis together with pictures of the rear bearing tensioner also and show how to do it tonight,
    I'm trying to make this Log on the forums to serve as a tutorial to put it together, thats why i post so many pictures.
    If someone likes they can download the log and make a pdf out of it.
    Joe
  7. #207
    Aug 2004
    3215
    Got the Z Axis Bearing Slide Installed, Here is a list of the hardware.
    4 - U-Bolts (5/16" x 2" x 4-1/2")
    5/16" I.D. Clear Hose
    Also Here is the 3/4" drill rod cut to 14 3/4" lengths and ground the ends at slight 45, they fit very tight into the Holes in the Z Axis Carriage.
    I will dremel the extra thread which sticks out.
    Edit: forgot to mention the hose lengths were cut to 2.75" and I will switch from a Lockwasher and nut to a Locking nut at the end of the U bolts.
    Attached Thumbnails Attached Thumbnails U-Bolt.JPG   Hose.JPG   Z Axis Bearing Slide.JPG   Z Axis Slide Installed.JPG
  8. #208
    Sep 2005
    69
    Hi Joe,
    I have to say that is a very simple solution, I love it. Aquick tighten of the U-Bolts and you get great contact on the drill rod by all of the skate bearings.
    You are a cleaver man.
    *bow down*
  9. #209
    Oct 2005
    36
    what fodder1 said.
    no more lusting after the ability to cast bearing mounts in my back yard.
    I think this idea has just simplified the hardware-store router design quite a bit......
    :banana: :banana: :banana: :banana: :banana: :banana: :banana: :banana: :banana: :banana: :banana: :banana: :banana: :banana:
  10. #210
    Jan 2006
    5
    Quote Originally Posted by whirlybomber
    what fodder1 said.
    Actually take a look at BEONE's design he started. He made basically a cast version of the angle aluminum bearing mounts. They look pretty sweet, since he made it a point to cast flat sides on the top and sides for ease of mounting. Pretty sweet if you have the ability to cast!!!! As for me, Joe's method will do fine.
    You must be approaching completion Joe....? Any more progress shots?
  11. #211
    Apr 2003
    598
    I like it...I tried to figure out how to use U-bolts, a few years back, and never came up with anything as elegant as this. I never came up with the last part...the tubing as a means to hold the bearing in position on the U-bolt.
    Do you have dimensions for the whole construct? I'd love to build one, just as a proof of concept model! The important elements would be the size of the rod (3/4"), the size of the angle, the length of the spacers for the bearings on the angle, and the size of the U-bolt.
    A VERY cool design. BRAVO!
    -- Chuck Knight
  12. #212
    Feb 2005
    2
    Joe, You do great work. I enjoy your build log.
    Would you post the your plan and parts list with measurements.
    Thanks Ron
  13. #213
    Aug 2004
    3215
    Quote Originally Posted by chuckknigh
    -- Chuck Knight
    are you just refering to the Z Axis?
    3/4" drill rod, skate bearing slides, using 5/16" bolts and one 5/16" nut for the aliumn. to bearing spacing which puts the bearing almost centered on the rod, and the u-bolt and hose is mentioned here.. http://www.cnczone.com/forums/showpo...&postcount=208
    the hose is only used as you said to hold the bearing into place.
  14. #214
    Aug 2004
    3215
    Quote Originally Posted by scrolleagle
    Thanks Ron
    I have not done a set of plans, what i did was draw the basic drawings in acad then imported dwg into siolid works extruded to proper thickness and then created the assemblies to make sure everything is lined up and works properly, If someone would like to make detailed drawings then they can from the dwg files or the solidworks files, I really do not have the time to sit down right now to make the drawings maybe later on i can.
  15. #215
    Aug 2005
    276
    Joe,
    I have just sat and read the whole post including the links posted. You are truely a man of vision and more over an acheiver, I looked a building a CNC router a few years ago I did the, "research eBay for slide and steppers" thing.. looked into geko drivers and ended up with analisys paralasys (Sp) late last year I decided on buying a Dayton 8x4ft router table off eBay todate it still is in transit I have phoned customs and I should have my baby in the next two weeks. Once again congrats. could you e-mail me as I would been keen to chat with you [email protected]
  16. #216
    Jan 2006
    11
    Quote Originally Posted by Salty72
    Joe,
    I liked Joe's New Router so much, I'm buying one of his kits.
    Steve
  17. #217
    Feb 2005
    921
    It is a really nice machine.
  18. #218
    Jul 2005
    100
    Joe check your pm
    cadfish
    http://www.burgiengineers.com/
  19. #219
    Dec 2004
    62
    Are there kits available?
    Herman
  20. #220
    Feb 2005
    2
    Hi, Joe
    Could you send me the DXF or DWG files.
    I down loaded the E- Drawing plans but am having trouble opening them.
    e-mail [email protected]
    Thanks, Ron
  1. Two more of Joe's CNC Model 2006
    By JLT in forum Joes CNC Model 2006
    Last Post: 01-31-2019, 02:27 AM
  2. [AU] Joe's 2006 Model
    By nat.andrews in forum Joes CNC Model 2006
    Last Post: 11-11-2013, 11:50 AM
  3. Electronics for a Model 2006
    By joegtp in forum Joes CNC Model 2006
    Last Post: 08-31-2011, 04:43 PM
  4. New to Joe model 2006
    By Darroll in forum Joes CNC Model 2006
    Last Post: 01-16-2008, 11:31 PM
  5. JOES cnc MODEL 2006 R-1 or R-2???
    By Khalid in forum Joes CNC Model 2006
    Last Post: 11-11-2007, 06:58 PM
