587,770 active members*
3,327 visitors online*
IndustryArena Forum > CAM Software > Mastercam > how do i taper a pocket wall with mill level 1
Results 1 to 2 of 2
Hybrid View
    Aug 2011
    121
    I have some square blocks 3x3. I need to cut a 2x2 pocket in the center but have the walls taper out instead of 90 degrees. I have X6 mill level 1 and a 3 axis miller. Is this kinda cut possible? I can have steps, and we are also hoping to keep the corners of the tapered walls as sharp as possible. Any ideas? I could possibly get a trial of level3
    Aug 2011
    121
    ok found the option under depth cuts, last place i looked. Anyways i can use a flat endmill and taper the wall and obviously there are steps. I want to try a ballmill, but in verify it if say i choose a pocket and add tapered walls the top of the wall is nowhere near the edge of the feature? It works just fine with a flat endmill. I tried different compensation types with no luck. Any ideas why this happens.
    Sorry 99% of our work is core milling
  1. Replies: 1
    Last Post: 04-07-2013, 08:50 PM
  2. Replies: 1
    Last Post: 11-30-2011, 07:51 PM
  3. Replies: 10
    Last Post: 12-03-2007, 04:47 PM
  4. HF Mill NMTB 30 Taper
    By rodzilla in forum Benchtop Machines
    Last Post: 09-04-2007, 12:23 PM
  5. CNC / Vert Mill research blues: Beating my head against a wall.
    By Skyshark in forum Uncategorised MetalWorking Machines
    Last Post: 08-10-2007, 07:38 AM
