587,449 active members*
3,002 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > G-Code Programing > How can I use the macro defined by DEFINE...AS
Results 1 to 2 of 2
    Mar 2009
    3
    Hi, everyone
    I'm using SINUMERIK 840D.
    If I define a macro by using "DEFINE....AS" instructor in "_N_UMAC_DEF", what should I do next in order that I can use it in my other main and subprograms?
    For example:
    In "_N_UMAC_DEF"
    DEFINE FixUnclamp AS (($A_DBB[160] B_AND 1)<>0)
    And I want to use the FixUnclamp in my main program.
    Or is the macro automatically ready to use because it is defined in default manufacturing macro define file "_N_UMAC_DEF"?
    Thanks.
    Jan 2009
    19
    I will try to look in my manuals today for some more info. Another way to do this is just put that program in the subprogram file and you can call it from any main or subprogram by simply entering the name of the program. For example you can call your sub. FIXUNCLAMP
    then in your main programs just write FIXUNCLAMP and it will jump to the sub run it then go back to the main. Hope this helps
  1. DEFINE REPEATABILITY ?
    By sharpshooter90 in forum Uncategorised MetalWorking Machines
    Last Post: 01-06-2009, 01:00 AM
  2. MC9-Define Plane menu. Where is it?
    By neilw20 in forum Mastercam
    Last Post: 05-09-2008, 04:41 PM
  3. Please define our hobby -
    By Stepper Monkey in forum Benchtop Machines
    Last Post: 07-10-2007, 01:32 AM
  4. Extra User Defined M functions
    By automizer in forum Haas Mills
    Last Post: 03-11-2006, 07:32 AM
  5. HAAS Mill G68 Not Defined Problem
    By arlenw in forum Uncategorised CAM Discussion
    Last Post: 01-20-2006, 06:19 AM
