Hello,
Can anyone tell me what I am missing that is causing the following problem.
I am attempting to engrave on the lip of a finished part along an arc. I thought the best way to accomplish this was with the G68 with R7. ( I need each letter about 7 degrees apart). I have it set up to rotate in the x-y axis. The first letter goes on fine, then I get a error saying Undefined G code as soon as it hits the first line with G68 on it as I attemp to rotate the axis before I do the second letter. If I remember correctly it is error 330. My books give me no more information than I get on the screen. I tried turning rotation offset for G68 on in Settings. This made no difference. The default offset is shown as 0.0 and it will not let me change it with the offset setting turned on or off. I can engrave in a straight line at any angle with out a problem. My book for this HAAS also says I can not use G91 with the ingraving G code, so I have not tried that yet.
I have probably forgotten something really simple and basic. I also forgot to bring a copy of the code home or I would have posted it here to help figure out what I have missed.
Arlen
