587,496 active members*
3,148 visitors online*
Results 1 to 5 of 5
    May 2010
    12
    help with fanuc i series
    Hello people.
    First i want to say, this forum is very very good, speciall thanks to all.
    I have an machine with a Fanuc i series control (see attach pictures)
    My problem is: i can't do DNC mode.
    I can transfer small files to memory of machine with rs232 cable, but i can't do DNC for big files...
    it's possible, if someone know, how to do??
    regards.
    joshuac
    Feb 2009
    23
    hello
    we hawe the same problem with murata wiedemann turret punch,ween we make big programs we devide these in .PAT
    HAWE NICE DAY
    May 2010
    12
    hello
    i think it's possible we active DNC function, i don't know how... I try to change some system values but without results
    regards
    joshuac
    2932
    If you select TAPE mode, does RMT display at the bottom of the screen? If so, try turning on SINGLE BLOCk switch and press CYCLE START. Does LSK flash at bottom of screen? If so, send the program from PC to the CNC. You should see the program displayed on the screen.
    May 2010
    12
    Quote Originally Posted by dcoupar View Post
    Yes it works.
    thanks @dcoupard i don't know what is TAPE mode...
    Now i can do big programs :rainfro:
    regards
    joshuac
  1. Help with Fanuc Series 0-M
    By accramachine in forum MetalWork Discussion
    Last Post: 10-25-2009, 11:50 PM
  2. Fanuc O-T Series
    By zanellan in forum Fanuc
    Last Post: 07-13-2009, 03:10 PM
  3. FANUC Series 18-M
    By Kristoffersen in forum Fanuc
    Last Post: 01-16-2009, 11:17 PM
  4. GE Fanuc Series 18-M
    By MGT in forum Fanuc
    Last Post: 02-20-2007, 07:02 PM
  5. Fanuc Series 10
    By kayleesdad in forum Fanuc
    Last Post: 05-09-2005, 08:30 PM
