587,708 active members*
3,298 visitors online*
Results 1 to 12 of 12
    Apr 2013
    1788
    Haimer vs Tschorn
    Everyone here (including me) seems to use the Haimer 3d-taster. At a local tradeshow I had the opportunity to examine a very similar product from Tschorn (see Tschorn 3D Testers - Penn Tool Co., Inc). It is slightly smaller than the Haimer and is coolant proof at about the same price. Their DREHplus model has a cylindrical rather than ball probe tip which would be great in the lathe. Has anyone had any experience with this brand?
    Feb 2006
    7063
    Re: Haimer vs Tschorn
    Not sure why you think ANY of those have a cylindrical tip, much less why that would be desirable. All I see anywhere in the Tschorn catalog is various sized ball tips, like every other probe.
    I would expect those to be fully comparable to the Haimer.
    http://www.tschorn-gmbh.de/downloads...%20English.pdf
    Regards,
    Ray L.
    Apr 2013
    1788
    Please see page 8 of the document that you linked for information on the DREH version that I mentioned. Setting lathe Z-axis tool offsets in problematic with a ball end.
    Mar 2013
    131
    I have seen the Tschorn ones in Germany. I sometimes spend nearly half the year over there. They are pretty nice. I didnt realize that they had a cylindrical tip for them.Thank you for mentioning this. I may have to pick one up when I am in Deutschland next
    Mar 2013
    131
    Found a video of the cylindrical probe.
    https://youtu.be/kacnj-kpErw
    Apr 2013
    1788
    Thanks for the video showing the cylindrical tip. You don't have to go to Germany to get one. They're probably cheaper there but they are also on Amazon!
    Mar 2013
    131
    Quote Originally Posted by kstrauss View Post
    One of my customers has a machine shop and they have about 50 of them. He said he would give me one.
    Mar 2016
    326
    Even with cylindrical tip z direction measurement will be no accurate. It's obvious that this direction is used just for orientative measurement (the scale is usually 0,1 mm instead of 0,01). So whatever tip u are using check z direction with tool.
    Jun 2006
    3063
    The DREHPlus does look handy for the lathe, but the new price of nearly $800 sure put a damper on my enthusiasm pretty darned quickly.
    Oct 2010
    670
    Quote Originally Posted by MichaelHenry View Post
    I was thinking the same thoughts. I wonder if I can get a similar tip for the Haimer.....
    The Body Armor Dude - Andrew
    Apr 2013
    1788
    I have made my own Renishaw probe tips but I've never tried one for the Haimer. A cylindrical tip should be relatively easy...
    Mar 2016
    326
    One more thing. With cylinder u need to get precise, specific height to contact in XY directions.
  1. Haimer 3d Taster
    By slowtwitch in forum For Sale Only
    Last Post: 05-06-2016, 02:07 PM
  2. Haimer 3D
    By whagkangmakulet in forum Tormach Personal CNC Mill
    Last Post: 01-20-2016, 08:43 AM
  3. which Haimer?
    By widget_maker in forum Tormach Personal CNC Mill
    Last Post: 12-06-2015, 03:34 PM
  4. Haimer 3D Indicator
    By Strip in forum Tormach Personal CNC Mill
    Last Post: 08-26-2015, 09:17 PM
  5. Haimer Zero Master
    By GeorgiaRaised85 in forum Calibration / Measurement
    Last Post: 04-06-2010, 12:48 PM
