You must program a spindle speed in MDI or in a program for it to just turn on. If you just power up the machine and hit spindle Forward or Reverse it will go no where.
Go to MDI mode and just type S1000 M03, then hit the start cycle button. After that you can start and stop and reverse the spindle and change speed within your machine capacity % wise.
Beware that if your last programmed speed in your program was 7500 rpm and you hit spindle CW while setting stuff up, the spindle will go to 7500 and not the 1000 you have in MDI. This you need to know for setting things up and expecting the spindle to go to 1000 rpm while say using an edge finder. You must go back to MDI and then hit start again to change the rpm back to the slower 1000. This mistake can really tear up some tools and indicators, which is why they have doors!
Mike
Two Haas VF-2's, Haas HA5C, Haas HRT-9, Hardinge CHNC 1, Bother HS-300 Wire EDM, BobCAD V23, BobCAD V28
