587,473 active members*
3,530 visitors online*
Results 1 to 6 of 6
    Dec 2010
    0
    Haas Offset Issue
    I have a 2011 Haas VF3. The issue is T2 is showing up at the bottom of the Offsets chart. so the Offsets go 1,3,4... and it appears at the bottom of the list after T200. What can cause this and how do I fix it?
    Dec 2008
    717
    Stupid Obligatory Helpdesk response: Did you try turning it off then back on again? (I assume you have)
    How long has it been like this?
    I assume you called your HFO? If not, CALL YOUR HFO!!! That is why they exist. Sorry I can't help. I'd almost guess that you'd need a software re-load.
    Tim
    Dec 2010
    0
    Thanks for the response. Yes I restarted it initially but its a new machine and for some reason it took several restarts for it to show back up.
    Dec 2008
    717
    Well, glitches do happen. I guess the good thing is that it is new. Get your HFO to get out there ASAP.
    Tim
    Dec 2010
    0
    Ya he's coming out next week to finish loading macros and all the extra programs ur supposed to get. I'll mention it to him
    Aug 2010
    579
    Try changing setting 201.
    Thanks,
    Ken Foulks
  1. Post issue to haas
    By BartD in forum Mastercam
    Last Post: 12-28-2010, 12:32 AM
  2. post issue haas/mastercam
    By BartD in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 12-24-2010, 06:57 PM
  3. Mach3 offset issue
    By u77171 in forum Machines running Mach Software
    Last Post: 12-18-2009, 06:50 PM
  4. Fanuc 16i variable offset issue
    By PCCDon in forum Fanuc
    Last Post: 11-26-2009, 08:04 AM
  5. Replies: 11
    Last Post: 06-17-2009, 09:41 PM
