587,439 active members*
3,674 visitors online*
Results 1 to 5 of 5
    Dec 2007
    28
    Mach3 offset issue
    I have been using Mach3 for a while now with no issues until now. I did something that gave my Z axis a 1" offset. If I want to plunge 1/2" I have to program it (G code) to plunge 1.5"?? If I don't do that i'll only cut air. Can anybody help me with this problem?
    35538
    Check your steps/unit in motor tuning.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Sep 2007
    359
    Check the offset page to make sure you are in G54 mode.
    Check to tool table to make sure you haven't got an offset on the tool number your using.
    HTH
    Dec 2007
    28
    Thanks for the help guys, I appreciate it. I'm pretty sure the steps/units is OK since if I jog the axis 1", for example, it moves an inch and the Z axis position indicator shows an inch. I'll check out the offset page and tool table.
    35538
    Is there a G43 tool length offset in your code?
    Gerry
  1. Fanuc 16i variable offset issue
    By PCCDon in forum Fanuc
    Last Post: 11-26-2009, 08:04 AM
  2. Mach3 scale issue
    By Chris64 in forum Mach Software (ArtSoft software)
    Last Post: 10-19-2009, 03:30 AM
  3. Replies: 11
    Last Post: 06-17-2009, 09:41 PM
  4. Eagle CAM Processor output - Mach3 Size issue
    By deleteallusers in forum G-Code Programing
    Last Post: 05-02-2007, 03:14 PM
  5. Help with selector switch wiring issue (***actually a motor issue***)
    By BEDFORD in forum Charter Oak Automation Support Forum
    Last Post: 04-07-2006, 09:19 PM
