587,642 active members*
3,590 visitors online*
Results 1 to 4 of 4
    Jan 2009
    16
    g540 y axis problem
    new to all this just hooked up xyz to g540 with mach 3
    x and z working fine unable to get y to work switched cable around stepper motors leads work okay iam thinking it might be be the g540 any suggestions
    thanks
    Mar 2008
    3655
    Hi meck11. Welcome to the Zone!
    So, you connected the Y cable to the X DB9 and Y worked? Did you also connect X cable to Y DB9? Did that work?
    CR.
    Jan 2009
    16
    y axis
    yes I connected y cable to x and it worked
    tryed all three motors nothing worked on y
    Mar 2008
    3655
    Sounds like you need to immediately call Gecko Tech support:
    Contact Technical Support
    If you have a technical question and would like to contact technical support,
    you can do so by the following means:
    Telephone:
    (714) 832 - 8874
    Fax:
    (714) 832 - 8082
    Email:
    [email protected]
    To send your drive in for technical evaluation, please contact our technical support department. If they tell you to send your drive in, then please send it to the following address with the completed return drive form. Geckodrive will evaluate the drive upon receipt and mail it back to you after inspection or repair free of charge.
    Servo Return Form
    Stepper Return Form
    Please note: Geckodrive will evaluate only the motor controls and no other system component. If motors or other non-Geckodrive electronics are sent to us, they will not be evaluated and a fee will be charged for return shipment of the system components.
    ATTN: Repairs
    Geckodrive, Inc.
    14662 Franklin Ave.
    Suite E
    Tustin, CA 92780
    CR.
  1. G540 debug problem
    By gotfdirtball in forum Gecko Drives
    Last Post: 11-02-2009, 10:45 PM
  2. G540 Spindle speed output voltage problem
    By georgef8 in forum Gecko Drives
    Last Post: 09-22-2009, 04:18 PM
  3. G540 Rev.1 has problem
    By sse4 in forum Gecko Drives
    Last Post: 02-25-2009, 02:48 PM
  4. G540 problem, steppers not moving
    By CS900 in forum Gecko Drives
    Last Post: 11-13-2008, 05:38 PM
  5. G540 fault problem
    By jemmyell in forum Gecko Drives
    Last Post: 10-21-2008, 11:50 PM
