Originally Posted by
jsheerin
I took a quick look at the step and direction outputs at the end of my db25 cable. I hooked pin 6 (z-axis step) to a 1kohm resistor to pin 20 (ground). At 5V that should make 5mA of current flow. I saw a max of about 4V which would be 4mA. My brain was getting frozen (along with my fingers), so it slipped my mind to measure a longer step pulse. However, I did look at the direction signal and that made it up to about 4.4V, or 4.4mA, so I'd say that's the max current that I was getting out of my port. Here's the pulse - 1V/div vertical, 0.5us/div horizontal, mach3 set to 2us pulses:
This is with the LPT port on the motherboard.
I read that the G540 needs 5mA to drive its inputs. Should I try loading my port with a lower resistance to see if it can source more current? If it can't, I assume that would mean I should look into getting a break out board for the LPT port. If it can source the current, what's the lowest voltage it can sag to for the G540 to still see the pulse as a pulse - 3.3V? Any comments appreciated.
How about an inexpensive pci card lpt.
Search the zone and you will find what other people use.
Warning: DIY CNC may cause extreme hair loss due to you pulling your hair out.
