Fiber metal laser cutting machine MT-F2513
Description:
We MORN company not only offer normal co2 laser machine, CNC router, but also we have metal laser cutting machine, like YAG metal laser cutter, and fiber metal laser cutting machine.
We have 500W power, 1KW and 2KW power, we use domestic power supply and imported power supply.
If you need more info, PLS contact us freely.
APPLICABLE INDUSTRY:
Fiber laser cutting machine is specially used for stainless steel and mild steel cutting, different power supply could cut different thickness. To 1KW, max thickness for mild steel is 10mm, stainless steel is 6mm; To 2KW, mild steel could reach to 16mm, stainless steel could reach to 8mm.
The cutting speed for fiber laser cutter is fast, and also the cutting edge is more smooth than YAG metal laser cutting machine and plasma cutting machine.
FROM ( www.morntech.com )
