CNC 2000W Metal Fiber laser cutting machine(GN-CF3015-2000W)
Equipment Features and Technical Advantages
1. The machine uses a moving gantry structure, imported high-precision screw and linear guide, smooth transmission, high precision.
2. Bed with the moving beam as a whole welded structure, roughing after annealing, and then the vibration aging treatment, can completely eliminate the stress of welding and machining, good rigidity, high accuracy can be maintained for a long time does not deform.
3. X, Y, Z axes are imported from Japan servo motor, high-precision, high- speed, high-torque, high inertia, stable performance and durable. Ensure the machine's high speed and acceleration.
4. Using many laser cutting control special function modules, powerful, human-machine interface, easy to operate based on the Windows operating system, fiber laser cutting machine CNC system integrated
5. Independent research and development of personalized nesting software, CNC cutting machine to achieve " full-time cutting, efficient cutting and high - nesting rate cut " core technology is the fundamental guarantee of effective material savings, improve cutting efficiency.
6. Cutting fiber laser head selection U. S. Lasermech produced special cutting head, and capacitive sensing, induction of high precision and responsive, the most stable and reliable performance.
7. Imported high - precision electronic control proportional valve, precise control of the cutting auxiliary gas pressure, in order to achieve the best cutting results.
8. Adopting world leading American IPG fiber laser and laser power;
9. Adopt Germany famous PA open CNC system;
10. Adopt Taiwan YYC gear and rack;
Accuracy standards: German standard more than six, Japanese standard more than two;
High precision gear and rack to ensure the mechanical accuracy over the course of seven meters in the scope of work.
11. Using Japan Panasonic servo motor and drive;
Using advanced Japan Panasonic A5 series servo motor and drive, it is automatic compensation the path of cutting and ensure the cutting precision.
12. Adopt fiber dedicated laser cutting head and automatic tracking system;
13. In view of the different national requirements of environmental protection design.
Steel dust-proof design more suit for environment protection requirement and the operator' health.
Applicable Materials
Stainless steel, carbon steel, alloy steel, silicon steel, spring steel, aluminum, aluminum alloy, galvanized sheet and other metal pipes and tubes.
Applicable Industry
It is widely applied in industrial pipeline processing, explosion-proof equipment, military industry, chemical industry, oil exploration, lamps and lanterns, metal processing, ironware, building, etc.
After-Sale Service
We can supply engineer go to your country to help you install machine and do training after-service together.
No Performance index parameter
1 Cutting area(length width) 3000mm 1500mm
2 X axis route 3000mm
3 Y axis route 1500mm
4 Z axis route 120mm
5 X/Y axis positioning accuracy 0.05mm/m
6 X/Y axis positioning accuracy +0.04mm
7 Maximum speed 70m/min
8 Maximum cutting thickness 16 mm
9 CNC system Weihong
9 Number of phase 3
10 Power rated voltage 380V
11 Frequency 50Hz
12 Total power protection grade IP54
List Date: 8/26/2014
For more info, click here to view the original listing: CNC 2000W Metal Fiber laser cutting machine(GN-CF3015-2000W)
On Sale For: $310000 + $0 Shipping
