587,348 active members*
5,547 visitors online*
Results 1 to 10 of 10
    Aug 2007
    422
    Cutting From a PDF
    Hello,
    this may be a stupid question, but I am gonna ask anyway. I have a rabbit laser with lasercut 5.3 and want to know how to take a PDF or JPG and cut it out. attached is a JPG and PDF of a airbrush stencil that I need to cut out. can anyone help guide me through making this work? Up till now all I have cut out were DXF's. Any help would be good
    Attached Files Attached Files
    Necessity is the mother of all invention (unknown)
    My club home page www.lhmac.org
    Dec 2008
    1258
    Your image is very low resolution and simple, so I would just redraw it but you could also vectorize it. Here's a really quick vector conversion, it needs cleaning (node reduction) at the very least before you attempt to cut it.
    I don't have access to my usual tools right now (I'm travelling) but if you have Corel I am sure you could achieve better results.
    Zax.
    Aug 2007
    422
    Thanks, I do not have corel. I have a bunch of these and other items that I would like to cut out and need to come up with a way to do it.
    Jun 2008
    69
    I don't know if this will help you at any way... ?
    Regards,
    Hannu
    Dec 2008
    1258
    I don't use it, but I believe Inkscape has vector conversion built in and it's free.
    Zax.
    Aug 2007
    422
    zax and notexpert, what software are you using?
    Dec 2008
    1258
    Quote Originally Posted by rcpilot82 View Post
    I use ArtCAM or GSP Omega, but didn't have those applications available as I am currently travelling so I used an older sign program (which didn't produce the best results).
    Zax.
    Jul 2008
    776
    Corel is one of best tools to extract any vector image from PDF and use for lasering. Of course you must pay some $$$ for Corel but this is standart for this business.
    Aug 2007
    422
    Thanks, I guess I'll have to see about learning Corel then.
    Jun 2008
    69
    I use mainly CorelDraw and Adobe Illustrator. Somehow I feel it's easier to explode PDF files with Illustrator and I'll also get better tracing results with it.
    From Adobe it is easy to export the files in eps, dwg, dxf, jpeg, bmp, etc... format. But still the main software for me is CorelDraw.
    Regards,
    Hannu
  1. How do you decide cutting speeds for cutting plexiglas?
    By angryManLT in forum Glass, Plastic and Stone
    Last Post: 05-04-2011, 03:28 PM
  2. Replies: 0
    Last Post: 01-26-2010, 02:53 AM
  3. Newbie needs help! cutting acrylic, and double cutting? 3040 machine
    By stephaniehamer in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 06-29-2009, 09:37 PM
  4. Can Watr jet cutting and laser cutting make endmills obsolete?
    By slashmaster in forum Benchtop Machines
    Last Post: 06-18-2009, 10:07 PM
  5. I need help about cutting heads which apply to apparel pattern cutting machine
    By sheepgrass in forum Mechanical Calculations/Engineering Design
    Last Post: 05-12-2006, 07:09 PM
