587,827 active members*
3,025 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > G-Code Programing > Creating A Loop With Different Work Offsets
Results 1 to 4 of 4
    Oct 2009
    26
    I have a 5-axis Mori Seiki vertical. I'm familiar with how to loop a block of code, but I'm now trying to loop a block of code 5 times while changing the work offset from G54, G55, G56, so on. I'm wanting to do this so that when I alter code at the mill, I don't have to change a ton of copied code OR macro code OR subprogram code. I've searched everywhere and can't seem to find an answer. Does anyone have an idea on how this could be done? Thanks in advance!
    Oct 2012
    85
    Re: Creating A Loop With Different Work Offsets
    Would something like this work?
    Startup code to your preference
    G0 G94 G17 G40 ......
    g54
    M98 p2222 (call to sub program, the O number)
    G55
    G56
    G57
    G58
    M02
    O2222
    program code
    M99 (return to calling program)
    Jul 2010
    118
    main prog:
    #100=54
    M98 P2000 L5
    O2000(SUB)
    G#100
    #100=#100+1(FOR NEXT REPEAT G5?)
    M99
    Feb 2015
    14
    Both of these will work...but if you are trying to loop the block of code as a do while loop instead of calling a subprogram or macro:
    #1=54.
    WHILE[#1LE58.]DO1
    G#1
    whatever machining code you want to do
    #1=#1+1.
    END1
  1. Help understanding work offsets and extended work offsets
    By tomvoutsas in forum Tormach Personal CNC Mill
    Last Post: 09-20-2013, 06:35 AM
  2. 3 Work Offsets?
    By KUWill in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 11-07-2012, 08:19 PM
  3. Work Offsets
    By Brad Morris in forum Mechanical Calculations/Engineering Design
    Last Post: 02-28-2010, 11:59 PM
  4. work offsets
    By porkchop21 in forum Bridgeport / Hardinge Mills
    Last Post: 09-25-2009, 05:39 AM
  5. Work Offsets
    By new2cnc in forum Mastercam
    Last Post: 04-30-2005, 04:04 PM
