587,794 active members*
3,333 visitors online*
Thread: work offsets
Results 1 to 2 of 2
    Jan 2007
    14
    work offsets
    i have a bridgeport torq cut 30 with a dx32 control running with a subplate. the question i have is what is the best way to set work offsets i do not have alot of machine expeirience so leahmans terms would be nice right now everything is set off the TLO with a gage block and i want to set the g54-59 to the 6 different stock sizes we run
    thanks in advance
    scott
    Haas VM3 (new baby)
    Bridgeport TorqCut 30 with a DX32 Control (old stepchild)
    Feb 2008
    44
    Quote Originally Posted by porkchop21 View Post
    thanks in advance
    scott
    I set my Z datum to the top of the vise base where material will sit. Then, offset the Z axis in your part program. For example, lets say I am machining 1/2" thick material sitting on 1.5" high parallels. I offset the Z axis 2" before the first tool change. Then G96 offset cancel just before M2/M22.
  1. Replies: 12
    Last Post: 04-05-2019, 10:21 PM
  2. Work Offsets
    By RMT in forum Mach Mill
    Last Post: 12-14-2008, 04:49 PM
  3. multiple work offsets
    By rbest27 in forum Surfcam
    Last Post: 01-25-2007, 10:02 AM
  4. work offsets
    By 5axisdan in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 07-04-2005, 04:17 PM
  5. Work Offsets
    By new2cnc in forum Mastercam
    Last Post: 04-30-2005, 04:04 PM
