In my application I need to use fixed bearing with vertical shaft. I will have a axial load of 3Kg and I am having trouble calculating if the bearing will be able to support the load.
I would like to use most standard ball bearing:
d=30 mm
D=62 mm
height: 16 mm
Base load dynamic: 14 600 N
Base load static: 8 400 N
I am not sure what the last 2 mean in real world application.. will it be able to support that axial load?
