I have a pretty large C3 Precision ground ballscrew (Z axis) that has some rust from the milling machine sitting in Extended storage. It appears to be above surface rust but below visible pitting/scaling
Is it salvageable? Anything I can dip it into to get some of it off (IE Toilet Bowl Cleaner, or Muriatic Acid, oil soaked 00 steel wool) without completely destroying it's accuracy?? I might be willing to replace it after the mill is completely operational but for now I am trying to get the best I can with what I have..
Its a real shame, It is 1.25" in diameter... Sounds Expensive...
