587,765 active members*
3,772 visitors online*
    Nov 2004
    44
    rust prevention
    I use 3" x 3" x 0.25" mild steel square tubing to build my CNC machine. I need to make sure I protect it from rust. I will be using a 4.5" wire grinder attachment to remove the rust already on the metal. What is the best way to stop future rust? I know I can buy the Rust-Oleum clean metal primer. Is there a better method and how many coats should I apply? I plan to spray some color over the primer. Any suggestions on what color I should use? Should I use dark colors (black, dark grey) or lighter colors (yellow, white, blue).
    Thanks,
    Apr 2003
    1873
    coolman,
    Why not protect all the precision areas and then sand blast it , which removes rust not grinds over it, then a good coat of primer and some epoxy paint to finish it off, any color but battleship gray
    Blue would be cool.
    35538
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
  1. Rust on tooling & toolholders
    By gbowne1 in forum MetalWork Discussion
    Last Post: 01-24-2006, 06:05 AM
  2. Rust on Cast Iron
    By ChrisJ in forum MetalWork Discussion
    Last Post: 05-18-2005, 07:06 AM
  3. Flood cooling rocks!!!!
    By JFettig in forum Benchtop Machines
    Last Post: 09-17-2004, 11:01 PM
