Originally Posted by
zavateandu
hey guys ,are you reading the description of his machine??????
please read carefully first and than give solution.
First of all he has FANUC 0M and he has no 1815 parameter or 1320 or 1321----dah???
the solution is simple man:make PWE=1 and ignore the alarm or if you press the can+reset will make it go away.
After that ,go to parameter 702,this is the limit on + for Z axes and must be between 1000-5000.
You must make this greater ,i use to do it 999999.
After , go away with the Z axes from the cam ,about 100mm ,and do a zero return again.
you will see is ok now.
go back to parameter 702 and do it back as you found it
make PWE=0
you are done!
