I've just started working with a Fadal VMC4020 with the 88HS control. I have a couple questions I would like input on.
First, we would like to set tools using a standard block/gage on the table surface and use the Z-height offset to set the part surface reference. I tried this when setting up the first job without success. The tool either wanted to rapid to the touch off height way below the part surface or when inputting a positive number representing the difference in height from the part surface to the touch off block the Z would over travel. What is the best way to set this machine so that once a tool is touched off we won't need to do it again when switching set ups?
Second, when running parts the machine will run fine for a little while then when a tool change is commanded the spindle will return to the tool change position and appears to want to orientate but doesn't seem to " lock in" to an oriented position. The control gives an error message that axis doesn't communicate with NC. What could be the problem here?
Thanks in advance for your help.
