587,646 active members*
2,972 visitors online*
Results 1 to 5 of 5
    May 2006
    343
    Z axis servo has been getting hot sitting at idle
    Any idea how to fix this?
    I adjust the Geckodrive, which pot to turn down a bit?
    Apr 2004
    733
    A servo motor should never be hot at idle. Tell us more on your z axis configuration. Is it direct drive or pulley reduction. What is the motor continuous torque rating? Z axis weight. Type of leadscrew and pitch.
    Gecko servo drive will always dither a bit when idle. Tuning can minimize but if there excessive force on the motor due to z axis weight, it will be difficult to fine tune it.
    May 2006
    343
    Re: Z axis servo has been getting hot sitting at idle
    there is no load on servo at rest from the Z axis.
    its a turnkey IHCNC, with a Kellig 1100 oz servo
    Jun 2005
    1015
    your gain is set too high causing too much dither
    May 2006
    343
    Great! I'll give that a shot. Thank you
  1. router has been sitting
    By BOATDUDEGUY in forum DIY CNC Router Table Machines
    Last Post: 04-22-2014, 12:36 AM
  2. Mini Mill coolant sitting and changing mix ratio?
    By Terry G in forum Haas Mills
    Last Post: 09-14-2012, 08:42 PM
  3. Tormach Tools- Not sitting flush with the spindle
    By vcatalasan in forum Benchtop Machines
    Last Post: 08-23-2011, 12:34 AM
  4. Maintenance on a sitting 1 1/2 yr old SX3 machine
    By idtkid in forum Syil Products
    Last Post: 05-22-2009, 08:44 AM
  5. Stepper heat >75C sitting on bench 100 rpm
    By Monte in forum Stepper Motors / Drives
    Last Post: 03-25-2008, 06:50 AM
