587,854 active members*
5,217 visitors online*
    May 2012
    0
    Z- Axis loosing steps
    i have an Optimum Bf 20l which i converted to cnc with the cnc conversion set.
    Everything is working fine except the z- axis.
    I can controll it with manual joging and it works great.
    But if i try to run a g-code the machine goes to e.g. +3.000 and should then plunge to -2.000. Instead it only plunges to something between these number(and never consistent!). Also the feedrate is a lot slower. As i said this problem occurs just by running a gcode, with normal control with the arrow keys there are no problems.
    I already tried to reduce / increase the feeds and also the acceleration.
    I also tried a different kernel speed.
    The power supply should also be ok (this problem occurs just when plunging down!)
    Any suggestions why the z- axis is behaving like that?
    Thank You!
    Aug 2006
    65
    One thing I have learned about Mach 3 it is sensitive to information input and if it is not correct it will drive you nuts I know this info is very general but you have to have a baseline and there is enough guys on the Mach site that will help you Step by step. In Mach3 PDF there is a setup to follow. I would go to the Mach site for that support it is easy to do that... You can't go wrong if you go to the source...
    9lrac9
    35538
    I'd look closely at the g-code. Can you post it here?
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
  1. loosing steps in z axis
    By macatoms in forum Benchtop Machines
    Last Post: 05-05-2012, 08:16 AM
  2. Axis loosing steps
    By Vogavt in forum Benchtop Machines
    Last Post: 01-07-2010, 06:01 PM
  3. Y Axis Bind and Loosing Steps
    By ranchak in forum Bridgeport / Hardinge Mills
    Last Post: 11-05-2009, 01:09 AM
  4. BP series 1 loosing steps
    By bartL in forum Bridgeport / Hardinge Mills
    Last Post: 07-16-2008, 06:55 PM
  5. Loosing steps
    By Normann in forum Automation Technology Products
    Last Post: 10-15-2007, 08:15 AM
