586,035 active members*
3,720 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > Z axis just stopped working on my TB6560 board
    Mar 2015
    8
    Exclamation Z axis just stopped working on my TB6560 board
    Hello, I have gotten into this wonderful world of CNC and decided to build my own. I got everything set up in Mach3, hooked everything up and after a few days of figuring everything out I have been milling out thin plywood and foam board with no problems. (I build RC planes and copters) Everything has been working perfect and today I turn on the computer, power up the TB6560 and zero my X, zero my Y and hit the up down for Z and nothing. I used it last night and all was fine. I must tell you this is my second TB6560 board. The first one did the exact same thing, just stopped on the Z. When that happened the first time I contacted the seller and they sent me a new board. Plugged it in and away we went, till now.
    I have tested the Z motor in the X & Y plug ins on the same board and it works fine. (Not the motor, connections or power)
    My questions are
    1. is there a reset or something I can do to this board that may fix it?
    2. is the TB6600 better to use?
    3. what would cause this to happen twice? (first board ran about 6 jobs, this board ran about 20 jobs)
    4. should I go to 3 separate driver boards instead of 1 for all three?
    Your help would be much appreciated!
    Thank you!
    Apr 2004
    5737
    Re: Z axis just stopped working on my TB6560 board
    Big surprise. Time to send it back, get another one, do another six jobs, blow it up, repeat...
    Andrew Werby
    Website
    Jan 2005
    1695
    Self destructing for no reason is the normal behavior for most tb6560 boards. The 6600 is much better, but might require a few mods for best performance.
  1. TB6560 4 Axis blue board
    By TheJollyRoger in forum Stepper Motors / Drives
    Last Post: 02-22-2015, 07:32 AM
  2. 5 axis breakout board and 3 single axis drivers tb6560, not working
    By MROX15 in forum Stepper Motors / Drives
    Last Post: 11-06-2013, 07:34 PM
  3. HobbyCNC pro A axis stopped working
    By j2sip in forum Hobbycnc (Products)
    Last Post: 03-17-2013, 05:02 AM
  4. TB6560 4 Axis Board
    By midget214 in forum Mach Software (ArtSoft software)
    Last Post: 09-10-2012, 01:03 PM
  5. need help with 3 AXIS (TB6560) CNC DRIVER BOARD
    By Jason Miller in forum CNC Machine Related Electronics
    Last Post: 08-11-2012, 03:34 AM
