Hello
I've been poking around with a Yaskawa USA REM servo motor. which should be matched with a CACR PR07 Amplifier . Those seem to be quite rare.
This motor holds a pair of 1500 counts per rev encoders. One is TTL, and the other 12v. Both square wave.
Can anyone advise a scheme or suggest an alternate (available) amplifier that will work with this combination.
The MPA servo amplifier I have only has settings for Encoders with multiples of 512 counts per rev.
An Emerson FX drive is incompatible in a number of ways. ;-)
Comments or advice? I don't know much about servo motor and amplifier compatibility. Perhaps an encoder change is my best option.
TIA
Cal
