586,069 active members*
3,714 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Y axis moves randomly in a direction
Results 1 to 4 of 4
    Oct 2009
    3
    I have DIY mach3 running cnc for 3 years with no problems - until now:
    when I want to move the Y axis (left or right) with the keybord (arrow up/down) it moves randomly in a direction.
    The same when I use the home button on the mach screen it moves randomly in a direction - mostly the wrong one.
    when I press the same keybord arrow twice (or more) the Y axis moves randomly
    Z an X work fine.
    I checked the hardware, limiting switches, cables, connectors, even swapped motor drives - no luck
    Any idea how to solve?
    can it be mach3 is causing it?
    Hans
    Oct 2013
    57
    Re: Y axis moves randomly in a direction
    Sounds like your power supplyhttp://www.cnczone.com/forums/newreply.php?do=newreply&p=1472424&noquote=1
    Feb 2007
    711
    I would check your direction pins from the computer to the breakout board/drivers.
    It sounds like wiring or pin problems, making intermittent contact.
    you could measure the voltage at the direction pin on the driver and see if that is the case.
    Oct 2009
    3
    Fixed it.
    Cable connector had loose connections (some time ok, moment later no connection) - so I did not know where it was and in what direction to go
  1. Z axis only moves in one direction
    By mklotz70 in forum Hobbycnc (Products)
    Last Post: 05-06-2020, 03:55 PM
  2. axis moves one direction. help
    By rs4race in forum Benchtop Machines
    Last Post: 01-26-2014, 10:20 PM
  3. Axis moves in same direction
    By mreitt in forum Mach Software (ArtSoft software)
    Last Post: 09-28-2013, 01:32 PM
  4. Keling 425oz/in randomly reversing direction??
    By mulligan in forum Stepper Motors / Drives
    Last Post: 05-17-2009, 11:15 PM
  5. A3977/Mach3 Direction changes randomly
    By kiltjim in forum Open Source Controller Boards
    Last Post: 12-09-2007, 03:04 AM
