I've seen some picture of the Syil DIY kits and noticed that everything is predrilled and threaded for fixing to the standard pickup points on the Sieg built machine.
Given the very precise alignment requirements for ballscrews published by many manufacturers just how is the alignment of the ballscrews achieved with this method, is it a case that the Sieg and Syil tolerences are so good (hard to believe!) that the Syil bits just bolt on or is there some adjustment built in to the ballscrew end supports/motors mounts and the ballnut block mounts?
