I'm ready to expand my axis! :banana: (every little bit counts)
So I start moving the axis and see what is the first thing that hits (and if it can be removed)
(Warning... Sorry for the dirty machine )
The X axis -->
I gained .04" just by bending the little bar holding the plastic cover out of the way (see left circle)
After that, the ballscrew was having some difficulties clearing the frame
I'm going to try to trim the frame a little with a dremel
If that is the case... I could gain .5"
The Y axis still have about .4" of traveling distance on the screw (I forgot to take under the machine to show... sorry)
I think I could use those .4" if I trim the motor bracket (as shown in the next pic)
Here is my dilemma.
The bracket is .75" thick.
I have .5" and .25" thick aluminum bars (but not .75")
1- I could use two bars to reach the desired thickness, but it would be more pieces, instead just of one solid pieces
2- I could try to manually trim the existing bracket (CNC fusion).. and hope I don't mess it up.
3- I could order .75" thick alum bar and wait for delivery
I'm thinking in trying #1 and see how it goes.. what do you guys think?
