Has anyone thought of mixing the X1 extended table and extended Y with a X2 column and R8 head?
I have and X2 minimill and I like the R8 tooling. But, I like the Y travel on the X1 with extended Y. The extended X table appears to be wider and longer than the table on the X2. Could you take an X1 base and mount the X2 column to it? Or would the X2 head mount on the X1 column?
Would you really gain enough to be worth the cost? Would you just be better of buying an X3 for the money spent?
Alan
