587,380 active members*
4,250 visitors online*
Results 1 to 2 of 2
    Mar 2013
    7
    x and y motor issues
    Finally got some time to work on my machine this weekend. I've got the z axis working just fine but the problem is with the x and y axis. When I jog them, (either one) they wont spin. They seem to be fighting to go both ways. They click (step?) one direction then the other direction. I rewired the x and y to match the z which works fine, still the same problem. Would it be in the ports and pins or in the motor tuning? Thanks for any help.
    Mar 2013
    7
    I disconnected the z and x from the BOB and wired the x axis into the z on the BOB to see if it was the wiring or the motor. The x axis motor worked fine in the z spot. It's not the wiring. Reconnected them back in their spots and again the z worked fine and the x was doing its thing again. All the info that I have or have gotten from searchs about pins and ports, this one has been the closest. >In the pins and ports, the z is set on 3 and 6, but the x is on 16 and 1, the y is on 14 and 7. I've changed the ports and pins around for x and nothing happens. I put it back on 16 and 1, and it acts "funny" again. It seems like the only place I get any movement with the x motor.Shouldn't the motor outputs be between the 2 and 9 pins? I thought that 1, 14 and 16 were inputs or for something else. It's something stupid and little, I can feel it, just don't have the experience in this area.
  1. mill motor issues. help please
    By Deano7/11 in forum Uncategorised MetalWorking Machines
    Last Post: 08-12-2010, 10:09 PM
  2. Motor voltage issues
    By Greg King in forum DIY CNC Router Table Machines
    Last Post: 10-08-2009, 04:07 AM
  3. 5.25 floppy motor issues
    By KsiR in forum CNC Machine Related Electronics
    Last Post: 05-10-2009, 11:33 AM
  4. Motor speed issues
    By rich_cree in forum Gecko Drives
    Last Post: 02-21-2009, 02:57 AM
  5. More Motor Issues
    By pzzamakr1980 in forum Benchtop Machines
    Last Post: 10-19-2007, 10:35 AM
