587,482 active members*
3,346 visitors online*
Results 1 to 13 of 13
    Aug 2006
    133
    X axis not constant: Any ideas?
    I’m setting up a new machine. I am using Mach 3 software and need some direction.
    As you can see in the picture when I cut the number 16 everything works perfect. The right depth, shape etc.. Everything seems to work exactly like I want it to. Now look at the shape above the 16. This is supposed to be a 1.5” square with a raised circle in it. The raised circle seems fine, the Y axis seems fine, but what is happening to the X axis? It is consistently off creating a slanted affect. It is being cut from a planar toolpath generated by Bob Cad. The Mach screen shows the cut perfectly, and watching the X axis reading on Mach seems to indicate I have no issues. I first thought I had a sticking problem with the ball screw and backlash nuts, but how could it be so consistently off if that’s the issue? I have no clue what to even look for next to fix this.
    Your help in resolving this issue is most appreciated.
    Jul 2010
    1183
    I'd look for the coupling slipping. Or if it's a flexible type
    with a lot of excess "springiness" to it.
    The screw could also be shifting end to end on dir change.
    Nut may not be tightened good enough
    Looks like a coupling is slipping at first glance to me...
    John
    Aug 2006
    133
    Thanks for the note microcarve,
    I doubled check my couplings and made sure they were tight. I also double checked to make sure there was no movement on the screw by trying to move it, is there a more accurate way to check this?? After I tightened everything up, I ran the test cut again. I get the same slant. It’s consistent, so I guess that’s a start.
    The couplings are the flex type, is there something I should do to these, or will I need to replace?
    Jul 2010
    1183
    Quote Originally Posted by becikeja View Post
    Looks like something is slipping mechanically.
    The spring coupling should be consistently wobbly if it were that, but
    you're losing the actual position, so that's probably not that.
    The nut for the axis could be shifting.
    It's something simple. It's an additive type of loss of position so
    it's something just not tight enough.
    It can't be much....
    I guess you did a run without the router running so you'd hear missing
    step sounds/glitches...?
    Got a picture of the setup?
    John
    Jul 2010
    1183
    It sure does look like a coupling or nut slipping the more I look at it.
    Couplings can seem tight but the shaft in them can still twist.
    Especially if there's any oil or grease on either shaft.
    If material or the router itself was shifting, that'd be very noticeable.
    It looks like it 'tries' to get back on track in a few places, so
    lost steps wouldn't be regained.
    It looks exactly like a coupling problem I had a while back.
    John
    May 2005
    1662
    Alignment marks on the motor shaft, coupler, and screw would tattle on a loose coupler. Easier said than done on some machines.
    I'm wondering if missed steps from over aggressive machine settings could cause the same effect ? Try replacing the G00's with G01's using your favorite text editor. Think of it as a fishing expedition
    I had a similar problem caused by driver timings but that's not a common cause. I'm with microcarve, the simplest answer is usually the correct one.
    Anyone who says "It only goes together one way" has no imagination.
    Aug 2006
    133
    I went through the entire machine to insure everything was tight. I slowed the machine down to 25 ipm and then to 10 ipm with the same results. I tried cutting at a depth of .05 inches to make sue that was not causing unnecessary drag. Same issue. I then redirected my tool path to move from top to bottom instead of from left to right. Similar results just much more random. I am coming to the conclusion that it has to do with either the bearings or the anti-backlash nut. When I turn the spindle off and listen it seems to still make a lot of noise when it moves. This does not seem right. I think the bearings may be shot and are causing unnecessary friction leading the motors to misstep. But what is puzzling is the repeatability of the misstep if it is indeed being caused by the bearings. Anyone seen this before??? Any other ideas??
    Jul 2010
    1183
    Welll....if it's not the usual simple mechanical problem, then
    there's the possibility of a few things.
    Backdriving. If motors are too weak. If it's a high lead screw.
    Anti-backlash Nut grabbing on direction change can cause that to happen.
    I'd turn off power to unlock the motors. Then see if I can move the
    axis by pushing it. Force it to backdrive. If it's easy to do, you
    could need motors with a little more holding power.
    You didn't mention what sort of screw or motors you have....?
    I guess a really bad bearing could cause it to be harder to move
    in one direction than another. Haven't seen that before though.
    John
    35538
    What may sound like bad bearings could be resonance.
    Try cutting your acceleration in half, though.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Jun 2009
    251
    Just my 2 cents, but i would bet my be-hind that you have so type of backlash compensation set in MACH that is causing that to happen, since it does fine number 16 that has very litle movement but when it has to change direction often it keeps over compensating in one direction.
    Feel free to take a torch on me if i am wrong, but i would like a nice cold beer if i am right !
    Tom
    Apr 2009
    5516
    Are you using ACME rod or allthread? How do you have your leadscrew fixed? If you made it too tight you might have overloaded the bearings if they're not angular contact bearings? Also do you have a flat on your drive shaft for the coupling, or is it a fairloc or other type of locking collar?
    Sometimes the linear bearing might stick in one direction but not the other? I would disconect the leadscrew, and check that the axis moves freely.,, Make sure your screw is in line and not bent. If you suspect it's software, you can disconnect the screw from the stepper, and put a flag on the shaft, and run the program. If the stepper's getting the right signals, then the flag will stop at two positions exactly the same each time....
    May 2005
    1662
    Yes, and I solved it in software parameters, specifically the step and direction timings. If the lost position is always on the same axis this isn't likely to be the solution.
    Have you tried swapping the x&y motors and drives ? Process of elimination backyard mechanic style
    That will tell you if the stepper is following commands. Good idea.
    If the stepper is dual shaft follow up with this: A flag on the screw and another on the back of the stepper will tell if things are rotating together. On a machine with open access laser pointers could be attached to the rotating bits and aligned to marks on a wall, now we're talking real accuracy . ( I'm half kidding, having some fun with the concept) We really haven't been told much about this machine such as how much that lost position means in terms of screw rotation.
    Aug 2006
    133
    I figured it out. After checking all the mechanical connections I determined there was nothing else that could be done. Then I went back to the software. Checked every setting and all looked correct. Then it hit me. I never went back in and changed the acceleration and velocity settings. How could I have possibly overlooked the acceleration and velocity settings? I made the necessary adjustments and all worked perfect. Thanks for pointing out all the things to check. It definately helped.
  1. TB6560 non constant voltage on X axis
    By telah in forum CNC Machine Related Electronics
    Last Post: 10-01-2010, 07:09 PM
  2. Constant Velocity problem with 4th axis
    By tiwanacote in forum Mach Mill
    Last Post: 03-20-2010, 02:25 AM
  3. A Axis Constant Rotation
    By 1ctoolfool in forum Haas Mills
    Last Post: 09-22-2006, 03:57 PM
  4. 4th Axis, need ideas
    By PEU in forum DIY CNC Router Table Machines
    Last Post: 07-04-2006, 02:55 PM
  5. need ideas on Y axis design
    By toolbox82 in forum Mechanical Calculations/Engineering Design
    Last Post: 02-25-2006, 02:40 AM
