587,421 active members*
3,177 visitors online*
Results 1 to 2 of 2
    Jun 2020
    1
    X axis gear wear
    Hi all,
    Got a problem with my 5x10 CNCRP Pro. Was running a 3D parallel cut and noticed the x axis slipped about 5mm - by the time I noticed it was too late and the X axis rack and pinion was worn - had noticeable metal dust along the axis edge - the pinion had a definite wear line of 1mm. Attached some picture - anyone have any idea how this could happen? Lose set screws?
    S
    35538
    Re: X axis gear wear
    No pic.
    Pinions wear out, and need to be replaced periodically.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
