587,281 active members*
3,420 visitors online*
Results 1 to 5 of 5
    Oct 2005
    278
    Question WTB small Laser cutter for 20GA SS.
    Anyone have a lead on a small (smaller than a one car garage) laser cutter?
    Can have a bad control but a good laser. Can be ugly. Just needs to cut 20GA SS and be under 6K. I can retrofit. Can have obsolete motors and drivers.
    In midwest preferred.
    PM or email
    [email protected]
    Nate.
    Ann Arbor Meechigan
    Jan 2006
    2985
    You're asking for a lot for $6k. You will need a laser with around 100W power to cut SS. You should also have some special beam delivery optics to give you a circularly polarized beam. Just that part, sans any mechanicals is bound to consume your entire budget. I think you might want to look into plasma cutting rather than laser. You could build a very nice plasma machine for the same price.
    Matt
    laser will be too expensive.... plasma will be better, if you trust Chinese one, will be under $6000.
    Feb 2010
    3447
    plasma would be more what you want and would do a fantastic job. Perfectly in your budget as well.
    Apr 2011
    69
    maybe you should add your budget for laser solution
    always provide the good resolution of laser cutting,laser marking,laser welding equipment for you. www.hanzlaser.com MSN: [email protected] Skype:lisaseekcn
  1. exhaust system for small garage w/laser cutter
    By shatterjack in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 04-04-2011, 06:43 PM
  2. Small laser cutter for few mils mylar only.
    By Otatiaro in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 03-17-2011, 05:44 AM
  3. CNC Plasma Cutter, Laser Cutter, Water Jet
    By antsals in forum Waterjet General Topics
    Last Post: 03-11-2011, 01:56 PM
  4. Advice Wanted buying a small laser cutter
    By Jolijar in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 08-17-2009, 03:34 PM
  5. Need to Cut 20ga Stainless...?
    By tof1 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 07-20-2008, 12:50 AM
