I'm going to make a couple hundred units of the part pictured (a little less than 4 inches long). I start with stock that is just a tiny amount oversized so I can mill it quicker as I don't have to mill the contour out of a whole sheet. The two holes will be threaded for M4. I'm looking for suggestions on work holding this part to cut the contour. The obvious solution would be to just screw it down with M3 screws. However, since M3 screws are pretty flimsy I was hoping to avoid that. Also, I don't think that holding it down with a vacuum table would work since the surface area is quite small. Any other suggestions how I could avoid having to use M3 screws?
